NTSC/Pal 2.0 TV Screen
- GAlvarez
We purchased the 2.0 NTSC screen and were trying to get this to work with a Raspberry PI 1 Model B+. We made the corrections to the Config.Txt file and it still did not work. When we connect via HDMI to a larger screen it works. Does this NTSC screen work with a model 1 B+ Rasp board? Thanks! Prof. Gary
- mikeysklar
Re: NTSC/Pal 2.0 TV Screen
This will work with your Pi model.
Did you test the RCA video as HDMI would not be relevant in this case.
This guide is the closest for setup:
https://learn.adafruit.com/using-a-mini ... i/overview
