Code error
ShirlySF
Code error
Post by ShirlySF »
Hey there, I'm having some trouble connecting my servo controller board with my Arduino board, and I'm not sure what's causing the issue. The library I'm using for my LX-16A motor from Hiwonder isn't working right - I keep getting a read timeout error, and the write function isn't working either. I've been using this library: https://github.com/madhephaestus/lx16a-servo 3 and I'm pretty sure I've got the code right, but it's still not working. Can anyone give me some advice on how to troubleshoot this? By the way, here's a picture of how I've got the board connected.
const int txPin = 1; // TX pin of the Arduino connected to the data input of the bus servo controller
const int baudRate = 9600; // baud rate of the bus servo controller
  Serial.begin(baudRate);
  // move servo 1 to position 1000
  int servoId = 1;
  int position = 1000;
  moveServo(servoId, position);
  delay(1000);
  // move servo 1 to position 2000
  position = 2000;
  delay(1000);
void moveServo(int servoId, int position) {
  // prepare the command packet
  byte commandPacket[] = {0x55, 0x55, 0x06, 0x03, servoId, position & 0xFF, position >> 8, 0x00};
  // calculate the checksum
  byte checksum = 0;
  for (int i = 2; i < 7; i++) {
    checksum ^= commandPacket[i];
  commandPacket[7] = checksum;
  // send the command packet to the servo controller
  for (int i = 0; i < sizeof(commandPacket); i++) {
    Serial.write(commandPacket[i]);
dastels
Re: Code error
Post by dastels »
My first thought is that it's because Rx/Tx on the UNO is connected to the serial-USB converter on the board (and I notice you have USB connected). You could try using software serial on another pair of pins. See https://docs.arduino.cc/learn/built-in- ... are-serial.
Re: Code error
Check the user manual for your controller board. Rx usually means the receiving pin for the board. So that should be connected to the transmit pin (Tx) of the Uno.
So it should be Tx->Rx and Rx->Tx instead Rx->Rx and Tx->Tx as in your photo.
dastels
Re: Code error
Post by dastels »
Good catch, Bill. Yes, it's always Tx from one board to Rx on the other, unless for some reason it's explicitly mentioned to be otherwise (in which case someone didn't know what they were doing).
dastels
Re: Code error
Post by dastels »
You know, you might be better off going somewhere more relevant for the hardware you're using. There might be something in reddit.
Return to “Arduino”
