I just completed a project using a pro trinket 5 V 16 MHz FTDI, and I ran into something I've never seen before.
The code I wrote compiled without a problem, then I pushed the reset button and got the normal, pulsing red LED.
I clicked upload and everything went as expected and at the end it said, "upload complete".
one second later I got this error code. avrdude: stk500_disable(): unknown response=0x30
but the code runs as intended, and the project works perfectly. What does that code mean, and is there something I should be concerned about because the project works?
eror code on pro trinket upload
- mikeysklar
Re: eror code on pro trinket upload
What else is connected to the Trinket Pro? Do you see the same error during upload if there are no other accessories?
Can you enable verbose upload output (File --> Preferences)? There might be some more details and you can copy the error message and paste in a code tag here.
