Handler for Momentary Button
- samtkc
Can someone provide example code for pushing a button value from a Momentary Button (IO Block) to a Pi Pico using CircuitPython? Basically, I want to set up a handler for the feed from a Momentary Button. I can do this in C using onMessage, but I don't know how to do this in CircuitPython.
- mikeysklar
Re: Handler for Momentary Button
This is from the Adafruit Pico guide CircuitPython section.
# SPDX-FileCopyrightText: 2021 Kattni Rembor for Adafruit Industries
Button example for Pico. Prints button pressed state to serial console.
REQUIRED HARDWARE:
* Button switch on pin GP13.
import time
import board
import digitalio
button = digitalio.DigitalInOut(board.GP13)
button.switch_to_input(pull=digitalio.Pull.DOWN)
while True:
print(button.value)
time.sleep(0.5)
- samtkc
Thanks for the example, though I guess I was not clear. I am looking for a way to push a value from the dashboard to the Pi Pico. The Momentary Button I referred to is a dashboard block. Also, I am fine with reading a value from the dashboard on the Pi Pico in CircuitPython. What I am looking for is a way to do this with a handler i.e. I do not want to be constantly checking the value of the dashboard Momentary Button. And similar to how this would be done in C using "onMessage".
- samtkc
Is this simply not possible???
- jwcooper
Here is a CircuitPython example that does an on_message for a feed sent from a dashboard. This example is using mqtt, which is the recommended approach for something like this:
https://github.com/adafruit/Adafruit_Ci ... ack.py#L79
