- Attached to RaspberryPi 3B+ (also has CRICKITHat) via the STEMMA Hat (PID: 4688) and worked great
- Unplugged it from there to re-route wires and now it will not show up on the I2C bus (reboots, hardware resets, etc.)
- Plugged the thing into a Raspberry Pi 4 with the v2 STEMMA Hat (PID: 5142) and it shows up
- Swapping back and forth and using all 4 outlets on the V1 hat does not get the LCD to show up
I2C LCD disappearing act
- edgjr
I'm not even sure where to start, but I've attached a 3V to 5V Level Booster (PID: 5649) to a generic 16x2 LCD with an I2C backpack (I2C address 0x27). Here's where it gets odd:
- barshatriplee
Re: I2C LCD disappearing act
Plz verify id if I2C interface is enabled in your Raspberry Pi. Omit the CRICKIT Hat and test the setup again to see if the LCD module shows up on the I2C bus.
- edgjr
Thanks, but that wasn't necessary - after resetting the CRICKIT (due to some other issues), the issue resolved itself.
