Hi there,
I have a question about the Adafruit TLC59711 4 channel RGB LED drivers.
It is statet that i can chain the modules. Connect CO->CI and DO -> DI, all other Pins(V+,GND,..) are also connected correctly.
My problem is that, when i want to drive the 13nd channel the 1st one also lights up, vice versa. So it seems that every channel from each board gets the same signal(tlc.setPwm(n,val) == tlc.setPwm(n+12,val)). NUM_TLC59711 is also set to 2.
Is there a way to drive each channel from the corresponding channel of the other board independend from another, or is this intendend as chained?
Thank you for your support.
Best regards.
Adafruit_TLC59711 Chain
Re: Adafruit_TLC59711 Chain
Please post the code you are using.
- Philipp_Kotek
#include "Adafruit_TLC59711.h"
#include <SPI.h>
#define NUM_TLC59711 2 //Number of Modules
//Arduino Nano Pinning
#define data 11
#define clock 13
Adafruit_TLC59711 tlc = Adafruit_TLC59711(NUM_TLC59711, clock, data); //Setup Modules
tlc.begin();
tlc.write();
tlc.setPWM(0, 65535); //set Ch1 to max value
tlc.write();
That shouldn't happen. Can you post a photo showing all of your wiring & connections?
- Philipp_Kotek
I have two boards.
Each open drain output channel of the LED Driver boards is connectet to a PMOS to increase the driving power.
V+ of the drive boards is powerd by 12V.
The Arduino Nano with 5V.
Each board functions properly but the communication between does not.
- Chain_Error_2.jpg (445.91 KiB) Viewed 168 times
- Chain_Error_1.jpg (403.38 KiB) Viewed 168 times
If you change the code to flash the LEDs, do both LEDs flash?
tlc.write();
delay(500);
tlc.setPWM(0, 0); //set Ch1 to min value
tlc.write();
delay(500);
- Philipp_Kotek
Now I got a really weard behaviour.
The first LED(Ch0) flashes and then the seconed LED(Ch12) lights up for the rest of the 500ms. Afterwards both are dark for 500ms.
Let's take the external circuitry out of the equation for now. Wire a couple of LEDs just between V+ and R0.
- Philipp_Kotek
I now noticed, that the first chip gets a little bit warmer than the second one.
Mybe the first one has a defect. I will replace it and then i will let you know.
