I have an Adafruit Feather HUZZAH ESP32 hooked to both a DS18B20 temperature sensor and a Power Switch (Controllable Four Outlet Power Relay Module version 2). Both are working fine and I can see the current temperature and turn the power switch on and off with a button in the Adafruit IO dashboard.
What I want to do is turn the power switch on when the temperature exceeds a limit. I started creating an action and could only see ways to send messages based on the temperature comparison.
Is there a way to turn on the power switch when the temperature sensor exceeds a specified value using WipperSnapper?
WipperSnapper Reactive Action Question
- embeddedprogrammer
Re: WipperSnapper Reactive Action Question
I think I figured this out: I needed to publish a message to the power switch with a 1 or zero.
I haven't seen it trigger yet but I think I may need to reboot the esp32.
OK, fyi after a reboot it turned on the relay.
- brubell
- Learn User Page
Yes! Is anything else causing issues for you?I think I figured this out: I needed to publish a message to the power switch with a 1 or zero.
