Adafruit Library for RGB LCD Shield throws warning on latest IDE
klcobley
Post by klcobley »
Having updated my arduino IDE to 2.1.0, I now find my project throws warnings related to the Adafruit Library for the RGB LCD Shield which is didn't used to in 1.8 (yes I've had arduino IDE for a while :-) ). The compiler report is:
C:\xxx\Arduino\libraries\Adafruit_RGBLCDShield\Adafruit_RGBLCDShield.cpp: In member function 'void Adafruit_RGBLCDShield::begin(uint8_t, uint8_t, uint8_t)':
C:\xxx\Arduino\libraries\Adafruit_RGBLCDShield\Adafruit_RGBLCDShield.cpp:119:43: warning: unused parameter 'cols' [-Wunused-parameter]
 void Adafruit_RGBLCDShield::begin(uint8_t cols, uint8_t lines,
the relevant parts of my code are:
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
#include <Arduino.h>
//... some stuff deleted...
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();//instantiate the display
//initialisation
void setup()
  Serial.begin(9600);// Start the serial port for debugging
  lcd.begin(16, 2);// set up the LCD's number of columns and rows:
//... rest of setup and main loop etc.
I appreciate that its a warning, and that probably everything is fine, but I like to compile free of warnings where I can so as to know I'm not making silly mistakes with things which still compile :-)
Is it just me (most likely) or is there a problem with the library ? I tried adding the third optional parameter to my call but it made no difference - its the columns variable it objects to..) and this was taken from the original example code..
The version of the library is 1.2.0
Many thanks,
Kevin.
adafruit_support_carter
Re: Adafruit Library for RGB LCD Shield throws warning on latest IDE
Yep, it's just a warn, and a pretty benign one, so can ignore.
A simple fix is to add a line like:
(void)cols;
in the Adafruit_RGBLCDShield::begin() function.
But of course the bigger question is why it's there to begin with. :)
klcobley
Post by klcobley »
Thanks - I'm glad its not just me !
Not used to errors in your libraries :-)
An actual error would be different. It would stop compilation and would need to be fixed. The wording in the message would have "error" also, instead of "warning".
The fact this is showing up now is most likely due to changes in the compilation flags being used by the Board Support Package.
klcobley
Post by klcobley »
sorry - should be more precise with language - ofc not an error, a warning as I said in the OP
but it is an "error" of the human kind in so much as the code looks like it was changed but the inputs not tidied up, which is what I meant :-)
Your solution will work for me and its probably a good way to go fixing the library so as not to break old code?
many thanks.
Yep, the change won't break anything. It's really does nothing. But it fools the compiler into thinking the parameter is being used and will suppress the warning.
Return to “Arduino”
