I am using CircuitPython 8 on a Metro M4 airlift lite. I have a project that requires as many PWM outputs as I can muster up. These will be driving LEDs.
Using the sample code for identifying PWM outputs (found at the bottom of https://learn.adafruit.com/circuitpytho ... python-pwm) I get the following output - which is pasted at the end of this post. According to the list, there are up to 25 pins identified as having PWM output. However, as I have been trying to work through them, I have come up with the following problems:
#1. If I try to assign PWM to pin 13 such as the following:
testPWM = pwmio.PWMOut(board.D13, frequency=100, duty_cycle=0)
#2. For pins MOSI/MISO/SCK, the notes on https://learn.adafruit.com/adafruit-met ... /pinouts-2 state "These are also used by the ESP32 so they should not be used for anything but SPI connectivity - not for GPIO." Does that mean that I can assign PWM to these pins anyway if I am not using the airlift thingy? Do I need to include some code to disable the ESP32 first?
#3. PWM on RX and TX: Is this just referring back to to pins D0 and D1?
#4. PWM on ESP_RX, ESP_CX: I don't see how these would be accessible as there is no physical pin for them.
Thank you for reading! I greatly appreciate this forum for all of its help! I know very little...
No PWM on: A0
PWM on: A1
No PWM on: A2
No PWM on: A3
No PWM on: A4
PWM on: A5
PWM on: D0
PWM on: D1
PWM on: D10
PWM on: D11
PWM on: D12
PWM on: D13
PWM on: D2
PWM on: D3
PWM on: D4
PWM on: D5
PWM on: D6
PWM on: D7
PWM on: D8
PWM on: D9
No PWM on: ESP_BUSY
PWM on: ESP_CS
No PWM on: ESP_GPIO0
No PWM on: ESP_RESET
No PWM on: ESP_RTS
PWM on: ESP_RX
No PWM on: ESP_TX
PWM on: LED
No PWM on: LED_RX
No PWM on: LED_TX
PWM on: MISO
PWM on: MOSI
No PWM on: NEOPIXEL
PWM on: RX
PWM on: SCK
No PWM on: SCL
PWM on: SDA
PWM on: TX
