the last lines of my eink display cannot be updated. I'm using the chipset "Adafruit_SSD1680". It's the same issue as here: viewtopic.php?p=950977&hilit=eink#p950977
Extending the dimensions as suggested in the post did not help. I tried it on a Raspberry Pi Zero 2WH and 3b+ Is the display faulty?
Thanks for helping in advance!
E-Ink 2.13" bonnet does not update bottom lines
- andrex32
- mikeysklar
Re: E-Ink 2.13" bonnet does not update bottom lines
Which Ada product# of display are you using?
Which example program are you running?
- andrex32
I've got the following model: ADA4687
I run the weather example script from here: https://learn.adafruit.com/raspberry-pi ... ation-code
I added a screenshot which looks very similar to the one in the other thread I mentioned.
- PXL_20230512_070255249.jpg (872.95 KiB) Viewed 283 times
- mikeysklar
Are you running the current Adafruit CircuitPython EPD release (v2.11.0).
This issue of being off the SSD1680 being shifted by 4 pixels was identified and patched specifically for your 2.13" model.
The Adafruit_SSD1680 class increases its width parameter to the nearest multiple of 8 before constructing its framebuffers. This results in the framebuffer width not matching the display width whenever the latter is not a multiple of 8 (as is the case for the 122x250 resolution of the 2.13" E-ink Bonnet for Raspberry Pi). One consequence of this mismatch is that graphics are shifted (by 4 pixels in the case of the bonnet) when the rotation of the display is set to 1 or 2.
This was addressed for the SSD1675 and SSD1675B in 8022b34 by distinguishing between the width and stride of the framebuffer. The same fix should be ported to the SSD1680 driver.
- andrex32
Yes, I'm running the version 2.11.0. It actually sounds like my problem, but unfortunately the problem still persists. When setting display.rotation to 0 there are the same problems, since the ticket says "No regressions encountered with rotations 0 & 3."
Any more ideas? And thanks for the help!!!
- Bildschirmfoto 2023-05-14 um 20.06.44.png (140.52 KiB) Viewed 266 times
- mikeysklar
We are probably looking at the same issue, but it apparently is unresolved.
Since the library is making some last minute calculations by increments of 8 try making a larger adjustment to the size parameter (overshoot the adjustments). Shift 122x250 to either 131x250 or 113x250. I moved the values by nine just both +/- since I’m not sure what effect they will have.
# Initialize the Display
display = Adafruit_SSD1680( # Newer eInk Bonnet
122, 250, spi, cs_pin=ecs, dc_pin=dc, sramcs_pin=None, rst_pin=rst, busy_pin=busy,
- andrex32
No luck unfortunately. I did some dimension tests, setting different height values:
* 113 until 120: display is totally distorted
* 121 until 128: bottom line pixelated (content moves up the more the value increases)
* 129 ...: display is totally distorted
- Case: display is totally distorted
- PXL_20230514_220729626.jpg (411.66 KiB) Viewed 260 times
- mikeysklar
Did you try the epd_simpletest.py?
I modified this to your model. Just curious if the demo code from the repo works since the library issue had already been patched.
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import digitalio
import busio
import board
from adafruit_epd.epd import Adafruit_EPD
from adafruit_epd.il0373 import Adafruit_IL0373
from adafruit_epd.il91874 import Adafruit_IL91874 # pylint: disable=unused-import
from adafruit_epd.il0398 import Adafruit_IL0398 # pylint: disable=unused-import
from adafruit_epd.ssd1608 import Adafruit_SSD1608 # pylint: disable=unused-import
from adafruit_epd.ssd1675 import Adafruit_SSD1675 # pylint: disable=unused-import
from adafruit_epd.ssd1680 import Adafruit_SSD1680 # pylint: disable=unused-import
from adafruit_epd.ssd1681 import Adafruit_SSD1681 # pylint: disable=unused-import
from adafruit_epd.uc8151d import Adafruit_UC8151D # pylint: disable=unused-import
# create the spi device and pins we will need
spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
ecs = digitalio.DigitalInOut(board.D12)
dc = digitalio.DigitalInOut(board.D11)
srcs = digitalio.DigitalInOut(board.D10) # can be None to use internal memory
rst = digitalio.DigitalInOut(board.D9) # can be None to not use this pin
busy = digitalio.DigitalInOut(board.D5) # can be None to not use this pin
# give them all to our drivers
print("Creating display")
# display = Adafruit_SSD1608(200, 200, # 1.54" HD mono display
# display = Adafruit_SSD1675(122, 250, # 2.13" HD mono display
display = Adafruit_SSD1680(122, 250, # 2.13" HD Tri-color display
# display = Adafruit_SSD1681(200, 200, # 1.54" HD Tri-color display
# display = Adafruit_IL91874(176, 264, # 2.7" Tri-color display
# display = Adafruit_IL0373(152, 152, # 1.54" Tri-color display
# display = Adafruit_UC8151D(128, 296, # 2.9" mono flexible display
# display = Adafruit_IL0373(128, 296, # 2.9" Tri-color display
# display = Adafruit_IL0398(400, 300, # 4.2" Tri-color display
#display = Adafruit_IL0373(
104,
212, # 2.13" Tri-color display
spi,
cs_pin=ecs,
dc_pin=dc,
sramcs_pin=srcs,
rst_pin=rst,
busy_pin=busy,
# IF YOU HAVE A 2.13" FLEXIBLE DISPLAY uncomment these lines!
# display.set_black_buffer(1, False)
# display.set_color_buffer(1, False)
# IF YOU HAVE A 2.9" FLEXIBLE DISPLAY uncomment these lines!
# display.set_black_buffer(1, True)
# display.set_color_buffer(1, True)
display.rotation = 1
# clear the buffer
print("Clear buffer")
display.fill(Adafruit_EPD.WHITE)
display.pixel(10, 100, Adafruit_EPD.BLACK)
print("Draw Rectangles")
display.fill_rect(5, 5, 10, 10, Adafruit_EPD.RED)
display.rect(0, 0, 20, 30, Adafruit_EPD.BLACK)
print("Draw lines")
display.line(0, 0, display.width - 1, display.height - 1, Adafruit_EPD.BLACK)
display.line(0, display.height - 1, display.width - 1, 0, Adafruit_EPD.RED)
print("Draw text")
display.text("hello world", 25, 10, Adafruit_EPD.BLACK)
display.display()
- andrex32
I tried the example and had to reboot my raspberry pi :-)
The pins for dc, rst, ... are different. Next to the chipset the comment says "2.13" HD Tri-color display", but mine is monochrome, but I guess it should be compatible. The test I reduced to just drawing a line diagonally and it still shows the pixelated bottom bar.
I tried then the chipset "Adafruit_SSD1675", which didn't show anything, BUT when I switched back again to Adafruit_SSD1680 the display almost showed the correct output.
I used this code to draw the line:
Please have a look at the attached image.
- PXL_20230515_202255522.jpg (379.44 KiB) Viewed 251 times
- mikeysklar
That diagonal line almost worked.
I think we are nearing opening an issue with the github repo. It seems the 1680 Mono 2.13" did not get the full integration package with additions to example code and guides.
One more thing to try that might be a useful data point. There is a epd_bonnet.py script which refers to the chipset as 1675B and was recently updated to support monochrome mode BMP (I think). Can you let me know what you see with this one? BMP File.
- andrex32
When using 1675B it's the same as 1675 and nothing happens on the screen. The buttons however work and I see logging info in terminal. When using 1680 the image and the drawing are shown (after pressing the buttons), however with distorted bottom lines again.
- mikeysklar
Are you comfortable opening an issue with the github repo?
Something to the extent of bottom 4 rows of pixels are not aligning on Adafruit 2.13" Monochrome eInk (with 1680 based chipset). This can be seen using the Raspberry Pi E-Ink Weather Station or the examples/epd_bonnet.py. The issue has come up before and it got a patch, but it does not appear to be working with the current library.
Include a description of your hardware setup, photo of the offset problem, library versions and a link to this forum discussion.
- andrex32
Ok, will do.
Thanks for the help!
