I ordered a matrix portal m4 off of digi-key, one of adafruit’s distributors, and it worked well for a couple weeks until the reset button snapped completely off when pressing it down one day.
I was wondering if there’s a way to fix this or get a replacement because I can’t go into boot mode anymore.
Matrix portal m4 broken reset button
- adafruit_support_carter
Re: Matrix portal m4 broken reset button
Do you have a soldering iron? Ideally, that shouldn't have happened of course. But it also potentially an easy fix with a bit of soldering.
- Infamous098
No I do not have a soldering ironadafruit_support_carter wrote: ↑Thu May 11, 2023 5:47 pm Do you have a soldering iron? Ideally, that shouldn't have happened of course. But it also potentially an easy fix with a bit of soldering.
OK, in that case, let's just replace it. Contact Digi-Key and can link them to this thread if needed. They should be able to send you a replacement.
Reply back here if you run into any issues with the replacement process.
- Infamous098
Ok thank you.adafruit_support_carter wrote: ↑Fri May 12, 2023 12:09 pm OK, in that case, let's just replace it. Contact Digi-Key and can link them to this thread if needed. They should be able to send you a replacement.
If I were to solder it, where on the board would I put solder to connect it back onto the board?
These four locations:
The two on the sides are structural - they are what help hold the button onto the board.
The two at the back are the actual signal pins.
