VL53l0x voltage levels
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
Mech_Instruct
Post by Mech_Instruct »
The module indicates that it has a regulator that take 5V and gives 2.8 to the chip. However the max voltage on the I2C lines is specified by the manufacturer at 3.6V. Since these lines are pulled up by resistors on the processor to the full 5V, then this would exceed the manufacturers maximum specified voltage for the I2C lines.
Does the module have an I2C level translator built on to it? If not, have you just found that 5V I2C works without an issue?
dastels
Re: VL53l0x voltage levels
Post by dastels »
Yes, the I2C lines are level-shifted to 2.8v on the breakout. See the schematic at https://learn.adafruit.com/assets/93507.
Return to “For Educators”
