I have been directed here by response to flagging broken devices against the orginal email order chain.
Not sure why I am sent to a forum to discuss replacements on failed device out of the packaging. Seems odd to be discussing in public order numbers etc for a private transaction, when the previous RMA was resolved quickly against the original email, but here goes.
I have received 6x Adafruit ESP32-S3 Reverse TFT Feather (4MB Flash, 2MB PSRAM, STEMMA QT)
[ID:5691] across two order numbers
1x in order 3064056-1916787552 which was for RMA 3058378 on a device with broken screen, delivered in a padded envelope
5x in order 3067488-4290362026 delivered in a larger cardboard box
All packaging good on receipt
Devices arrived on same day so all 6 were unpacked, and I can't tell if the broken screen was in the box or envelope.
I have tested all 6 devices for basic boot / bootloader
4 are good, show the expected sample display code and can switch over to drive mode with double press
1x has a broken screen again
1x does not light the display at all but the device gets much hotter than it should
Attached images show the broken screen on 1, and for the other where the screen looks physically fine but does not otherwise work, thermal images showing hot spots on the board.
I ALSO have a problem with one of the VL6180X boards, I have not got through testing them all yet, but 1 initially locked up after ~1 hour of measurement and now no longer enumerates on i2c so we the "no device on address" error at startup.
I have had VL6180X boards running for days stable, so I know they should be both reliable and when this address failure happens, something is compromised.
Switching between this bad board and a good one on all the same STEMMA-Q wiring is a simple and repeatable proof.
Require RMA on 2x Reverse TFT s3
- big_red_frog
- S3 side, middle of board is hot
- img_thermal_1684090345742.jpg (44.75 KiB) Viewed 49 times
- TFT side, end of display next to single button is hot
- img_thermal_1684090332522.jpg (36.04 KiB) Viewed 49 times
- broken display
- 20230514_144932.jpg (270.54 KiB) Viewed 49 times
- mikeysklar
Re: Require RMA on 2x Reverse TFT s3
Thank you for the detailed writeup.
This is your approval for two replacement Reverse TFT ESP32-S3 and one VLX6180X. You can write to [email protected] and provide them with this forum link as your RMA authorization. They will also need your order number (you do not need to share that with the forums).
- big_red_frog
Thanks for this.
Please note the very first caveat if being directed here was...
1) Tell us what product you are asking about, your Adafruit order number, and when you purchased the item
