QT PY ESP32-S2/S3 not working with sample sketches
jjjjkem
Post by jjjjkem »
I just received 2 new QT PY ESP32-S2 and 2 new QT PY ESP32-S3. I have run the following tests on each board with the same problem results. I also have several QT PY SAMD M0 boards that all work perfectly with these example sketches.
I am able to successfully run the Adafruit Testbed/I2C_SCAN with the ESP32's and the STEMMA connections and addresses are detected, on the secondary I2C port.
When connected to Adafruit 7-Seg Display (https://www.adafruit.com/product/881) via STEMMA I am unable to get the Adafruit example sketch Adafruit LED Backpack Library/sevenseg to work. The display never lights up at all. I have tried to edit the example sketch with the code noted from website page https://learn.adafruit.com/adafruit-qt- ... -scan-test "Note we are using the STEMMA QT port here, that means we need to reference Wire1 for I2C communication and also add Wire1.setPins(SDA1, SCL1) in our code in setup()" but with no luck.
Same problem exists wit the ESP32's connected via STEMMA to Adafruit I2C Stemma QT Rotary Encoder Breakout with NeoPixel - STEMMA QT / Qwiic and trying to run the Adafruit example sketch Adafruit Seesaw Library/encoder. The sketch runs and is unable to find the Seesaw on the default address.
I have a sketch using both of these STEMMA devices running perfectly on my QT PY SAMD21 M0 and want to move the code to a ESP32 so I can connect with the WipperSnapper IOT. Perhaps there is another MCU choice that will work with the libraries that I am using.
Any advice please.
mikeysklar
Re: QT PY ESP32-S2/S3 not working with sample sketches
Post by mikeysklar »
We should be able to get you going with these QtPy's.
Can you post your modified code with the Wire1.setpins().
You will need to turn on the I2C power as well as seen in the testbed code.
https://learn.adafruit.com/adafruit-qt- ... an-3108213
#if defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
  // turn on the I2C power by setting pin to opposite of 'rest state'
  pinMode(PIN_I2C_POWER, INPUT);
  delay(1);
  bool polarity = digitalRead(PIN_I2C_POWER);
  pinMode(PIN_I2C_POWER, OUTPUT);
  digitalWrite(PIN_I2C_POWER, !polarity);
#endif
jjjjkem
Post by jjjjkem »
Here is the modified code for the LED backpack/sevenseg using the ESP32-S3. It compiles without error but still does not work. Sevenseg display has a small green LED that indicates it's getting power but the sketch does not light up the display. The display works fine with other SAMD MCU's running this same test sketch.
Thank you for your help.
  This is a library for our I2C LED Backpacks
  Designed specifically to work with the Adafruit LED 7-Segment backpacks
  ----> http://www.adafruit.com/products/881
  ----> http://www.adafruit.com/products/880
  ----> http://www.adafruit.com/products/879
  ----> http://www.adafruit.com/products/878
  These displays use I2C to communicate, 2 pins are required to
  interface. There are multiple selectable I2C addresses. For backpacks
  with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
  with 3 Address Select pins: 0x70 thru 0x77
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
#define DEFAULT_I2C_PORT &Wire
#if defined(ARDUINO_ARCH_RP2040) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32S2) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3_NOPSRAM) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32_PICO) \
    || defined(ARDUINO_SAM_DUE)
  #define SECONDARY_I2C_PORT &Wire1
#endif
Adafruit_7segment matrix = Adafruit_7segment();
#if defined(ARDUINO_ADAFRUIT_QTPY_ESP32S2) || \
    defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3_NOPSRAM) || \
    defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3) || \
  // ESP32 is kinda odd in that secondary ports must be manually
  // assigned their pins with setPins()!
  Wire1.setPins(SDA1, SCL1);
#endif
#if defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S3)
  delay(1);
#endif
#ifndef __AVR_ATtiny85__
  Serial.begin(9600);
  Serial.println("7 Segment Backpack Test");
#endif
  matrix.begin(0x70);
  // try to print a number thats too long
  matrix.print(10000, DEC);
  matrix.writeDisplay();
  delay(500);
  // print a hex number
  matrix.print(0xBEEF, HEX);
  delay(500);
  // print a floating point
  matrix.print(12.34);
  delay(500);
  // print a string message
  matrix.print("7SEG");
  delay(10000);
  // print with print/println
  for (uint16_t counter = 0; counter < 9999; counter++) {
    matrix.println(counter);
    delay(10);
  // method #2 - draw each digit
  uint16_t blinkcounter = 0;
  boolean drawDots = false;
  for (uint16_t counter = 0; counter < 9999; counter ++) {
    matrix.writeDigitNum(0, (counter / 1000), drawDots);
    matrix.writeDigitNum(1, (counter / 100) % 10, drawDots);
    matrix.drawColon(drawDots);
    matrix.writeDigitNum(3, (counter / 10) % 10, drawDots);
    matrix.writeDigitNum(4, counter % 10, drawDots);
    blinkcounter+=50;
    if (blinkcounter < 500) {
      drawDots = false;
    } else if (blinkcounter < 1000) {
      drawDots = true;
    } else {
      blinkcounter = 0;
    delay(10);
mikeysklar
I had to wire up my Qt Py ESP32-S2 to reproduce the issue. The key is this line:
matrix.begin(0x70, &Wire1);
We need to tell the matrix constructor which I2C bus to use so pass it a second argument to the STEMMA I2C connector.
I re-arranged your modifications to the code for troubleshooting, but this should get you going. You might need to uncomment the PIN_I2C_POWER.
  Serial.begin(115200);
/*  pinMode(PIN_I2C_POWER, INPUT);
  delay(1);
  digitalWrite(PIN_I2C_POWER, !polarity); */
  delay(500);
  delay(500);
  delay(500);
  delay(500);
  delay(10000);
    delay(10);
    blinkcounter += 50;
      drawDots = false;
      drawDots = true;
    } else {
      blinkcounter = 0;
    delay(10);
jjjjkem
Post by jjjjkem »
Thank you Scott, the changes you posted worked fine for the 7seg example sketch using the QT py ESP32-S2. I did not need to uncomment the PIN_I2C_POWER. If I do uncomment that PIN_I2C_POWER, it does not compile "Compilation error: 'PIN_I2C_POWER' was not declared in this scope".
I still am having no luck with the Adafruit seesaw Library/encoder basic example sketch. I added some of the change you made to the 7seg sketch, and it compiles, but it still does not find the seesaw on the default address. Console message is:
Looking for seesaw!
Couldn't find seesaw on default address
Here is the code edits for the seesaw that I tried.
 * This example shows how to read from a seesaw encoder module.
 * The available encoder API is:
 *      int32_t getEncoderPosition();
        int32_t getEncoderDelta();
        void enableEncoderInterrupt();
        void disableEncoderInterrupt();
        void setEncoderPosition(int32_t pos);
#include "Adafruit_seesaw.h"
#include <seesaw_neopixel.h>
#define SS_SWITCH        24
#define SS_NEOPIX        6
#define SEESAW_ADDR          0x36
Adafruit_seesaw ss;
seesaw_NeoPixel sspixel = seesaw_NeoPixel(1, SS_NEOPIX, NEO_GRB + NEO_KHZ800);
int32_t encoder_position;
  while (!Serial) delay(10);
  delay(1);
  digitalWrite(PIN_I2C_POWER, !polarity);*/
  delay(500);
  Serial.println("Looking for seesaw!");
  if (! ss.begin(SEESAW_ADDR) || ! sspixel.begin(SEESAW_ADDR)) {
    Serial.println("Couldn't find seesaw on default address");
    while(1) delay(10);
  Serial.println("seesaw started");
  uint32_t version = ((ss.getVersion() >> 16) & 0xFFFF);
  if (version  != 4991){
    Serial.print("Wrong firmware loaded? ");
    Serial.println(version);
    while(1) delay(10);
  Serial.println("Found Product 4991");
  // set not so bright!
  sspixel.setBrightness(20);
  sspixel.show();
  // use a pin for the built in encoder switch
  ss.pinMode(SS_SWITCH, INPUT_PULLUP);
  // get starting position
  encoder_position = ss.getEncoderPosition();
  Serial.println("Turning on interrupts");
  delay(10);
  ss.setGPIOInterrupts((uint32_t)1 << SS_SWITCH, 1);
  ss.enableEncoderInterrupt();
  if (! ss.digitalRead(SS_SWITCH)) {
    Serial.println("Button pressed!");
  int32_t new_position = ss.getEncoderPosition();
  // did we move arounde?
  if (encoder_position != new_position) {
    Serial.println(new_position);         // display new position
    // change the neopixel color
    sspixel.setPixelColor(0, Wheel(new_position & 0xFF));
    sspixel.show();
    encoder_position = new_position;      // and save for next round
  // don't overwhelm serial port
  delay(10);
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if (WheelPos < 85) {
    return sspixel.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if (WheelPos < 170) {
    WheelPos -= 85;
    return sspixel.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return sspixel.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
mikeysklar
I'm Mikey not Scott.
The PIN_I2C_POWER is only necessary for specific models. It does not exist on the Qt Py ESP32-S2.
The Seesaw encoder might be the same issue that the 7-seg matrix display had. The constructor needs to know which I2C bus to use.
change this:
Adafruit_seesaw ss;
to this:
Adafruit_seesaw ss(&Wire1);
jjjjkem
Post by jjjjkem »
Hi Mikey,
Thanks for the edits, but seesaw encoder sketch still did not recognize seesaw on default address. It was the neopixel part that also needed to be edited. I replaced the 2 lines as follows and the seesaw/encoder basic example sketch now works fine with the QT py ESP32-S2. I'm pretty sure the ESP32-S3 will work fine also.
// Adafruit_seesaw ss;
// seesaw_NeoPixel sspixel = seesaw_NeoPixel(1, SS_NEOPIX, NEO_GRB + NEO_KHZ800);
seesaw_NeoPixel sspixel = seesaw_NeoPixel(1, SS_NEOPIX, NEO_GRB + NEO_KHZ800,&Wire1);
Thanks again for your support.
mikeysklar
Good find on the seesaw_NeoPixel also needing the I2C bus argument.
Agreed, this should just work with the ESP32-S3.
