Trinkey_QT2040_Enviro_Gadget 2
dpuerto
Post by dpuerto »
This project took a backburner. I tried to fire it up. I followed everything I could. I tried to copy the firmware and the project files per the following links:
https://learn.adafruit.com/diy-trinkey- ... -with-u2if
https://learn.adafruit.com/circuitpytho ... 3098088-29 [firmare]
https://learn.adafruit.com/adafruit-scd ... cuitpython
But nothing... Errors trying to read the imports... Worse. I tried to use the second turkey and one of the buttons (RESET) broke off while I was holding it to try and put into my USB port.
I tried to use serial on macOSX and the MU editor. It's not a local Python issue, but now I am in a pinch withthese trinkeys. While it used to read CircuitPython, now the disk reads RPI-RP2... regardless which Trinkey I am using... and I only tried the install on one of them... and Idk what to do about the one that broke... should I attempt a solder (I don't even have these tools yet...) or send it back? That broke wayyy too easy. Think the pressure to press a key on your keyboard or a piano key max.
dastels
Re: Trinkey_QT2040_Enviro_Gadget 2
Post by dastels »
First, RPI-RP2 is the bootloader drive, ready to have a UF2 file copied to it. Make sure you aren't accidentally holding down the BOOT button when connecting/resetting.
For getting CircuitPython installed see https://learn.adafruit.com/adafruit-tri ... cuitpython.
As for the broken board... how long ago did you buy it, and can you post a clear closeup of where the button should be?
dpuerto
Post by dpuerto »
dastels wrote: Mon May 15, 2023 10:18 pm First, RPI-RP2 is the bootloader drive, ready to have a UF2 file copied to it. Make sure you aren't accidentally holding down the BOOT button when connecting/resetting.
Thanks Dave.
I followed these directions again. I have the Firmware copied onto the Volume and I have copied CircuitPython a well and the Volume reads CircuitPython. So I copied the /lib/ and other code.py from the .zip that was provided for the trinkey+scd-41 and it's still struggling with the imports... :-\
File "<stdin>", line 6
SyntaxError: invalid syntax
Line 6 is `import board`
I'll upload a photo soon of the broken reset.
dpuerto
Post by dpuerto »
Yeah, just keeps saying it can't read the board, but in the Serial reads: Adafruit CircuitPython 8.0.5 on 2023-03-31; Adafruit QT2040 Trinkey with rp2040. I am also using the code from the CircuitPython 8 repo
dastels
Post by dastels »
What firmware? CircuitPython IS the firmware.
Hmm. Please post the first dozen lines or so.
dpuerto
Post by dpuerto »
from boot.py:
import usb_cdc
usb_cdc.enable(data=True)
from environmon.py
import time
import board
import usb_cdc
import adafruit_scd4x
from adafruit_bme280 import basic as adafruit_bme280
import neopixel
#--| User Config |-----------------------------------
DATA_FORMAT = "JSON" # data format, CSV or JSON
DATA_RATE = 5 # data read rate in secs
BEAT_COLOR = 0xADAF00 # neopixel heart beat color
BEAT_RATE = 1 # neopixel heart beat rate in secs, 0=none
# check that USB CDC data has been enabled
if usb_cdc.data is None:
print("Need to enable USB CDC serial data in boot.py.")
while True:
pass
# setup stuff
i2c = board.I2C() # uses board.SCL and board.SDA
# i2c = board.STEMMA_I2C() # For using the built-in STEMMA QT connector on a microcontroller
scd = adafruit_scd4x.SCD4X(i2c)
scd.start_periodic_measurement()
bme = adafruit_bme280.Adafruit_BME280_I2C(i2c)
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1)
Also, ls /dev/tty.* via Terminal returns:
/dev/tty.BLTH /dev/tty.URT1
/dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem14601
And then running, screen /dev/tty.URT1 14601 shows:
SetTTY (fd 5): ioctl failed: Invalid argument
Attached my misfortune
dastels
Post by dastels »
Let's get that broken switch dealt with. Please email [email protected] with a link to this thread, your order number, and request the replacement of one Trinkey QT2040.
I don't see a problem with that code. What is in code.py (or main.py)?
What are you doing to get the syntax error?
dpuerto
Post by dpuerto »
I contacted them. By the way I have two sensors. One for inside and one for outside, sadly one of them just broke when I was trying to hold the button and insert into my USB. Maybe it can be salvaged.
Here is what I am doing. I believe I followed everything to the letter for the Trinkey and the SCD41 to use in Tandem. I am using MacOSX and Mu editor and terminal to attempt to read the code on the trinkey... but it's having trouble loading the imports starting with import board. I think that the firmwave i downloaded (adafruit-circuitpython-adafruit_qt2040_trinkey-en_US-8.0.5.uf2) is not reading correctly. Idk. I'm new to hardware.
In MU Editor:
>>> [D
... Traceback (most recent call last):
File "<stdin>", line 2
dastels
Post by dastels »
On MacOS it's usually the usbmodem device. I don't recall ever seeing a URT device.
Can you post everything from the REPL leading up to the complaint about the import?
Where does the code come from that is causing the error?
dpuerto
Post by dpuerto »
I levied the port number from the /dev/tty.usbmodem, but the URT device is what appears and disappears when I insert and remove the trinkey from the usb port.
I went through all the steps again (leading up to the direct reading with U2IF)
and this is what it returns:
File "enviromon.py", line 6, in <module>
import board
File "/Library/Python/3.8/site-packages/board.py", line 22, in <module>
from adafruit_blinka.agnostic import board_id, detector
File "/Library/Python/3.8/site-packages/adafruit_blinka/agnostic/__init__.py", line 21, in <module>
chip_id = detector.chip.id
File "/Library/Python/3.8/site-packages/adafruit_platformdetect/chip.py", line 138, in id
raise RuntimeError(
RuntimeError: BLINKA_U2IF environment variable set, but no compatible device found
I've been unsuccessful using the u2if_trinkey_qt2040_rp2040.uf2 firmware recommended in the instructions when inserting in bootmode... So I've flash nuked and used adafruit-circuitpython-adafruit_qt2040_trinkey-en_US-8.0.5.uf2 and the Volume reads as CIRCUITPY, so I continue with the procedures. All my python packages appear to be installed correctly... everytime I run through the install procedure it says that the dependencies are already satisfied... I followed the homebrew install instructions for the MacOSX also.
dastels
Post by dastels »
It looks like the code is trying to run on your mac, not the RP2040.
dpuerto
Post by dpuerto »
This could be. Maybe I am just unfamiliar with the process? I accessed the volume in Terminal, and then I typed python3 environm.py //// I am thinking about I would run any application from the command line?
dastels
Post by dastels »
python3 environm.py loads and runs (or tries to) environm.py on your Mac, not the RP2040. Python3 (i.e. CPython) isn't CircuitPython.
Read the CircuitPython guide: https://learn.adafruit.com/welcome-to-circuitpython.
dpuerto
Post by dpuerto »
ok, I think you are right. Back to using the Mu editor, I was able to follow the Neo pixel example and flash the red light, and then changed the RGB values and was able to achieve yellow and green so it's working. When I replaced the code.py with the environmon.py code it says that "Need to enable USB CDC serial data in boot.py."
So I am googling this but this is my boot.py:
`import usb_cdc
usb_cdc.enable(console=True, data=True)`
dastels
Post by dastels »
Note that CircuitPython requires *either* code.py or main.py on the CIRCUITPY drive. Whichever of those you have there will be loaded and executed.
