400x240 Sharp Display - Can't Use Full Screen
fredb_394
Post by fredb_394 »
I have recently purchased the Adafruit Sharp Memory display of size 400x240 pixels (2,7"). I am using an Arduino Mega to control it. I have tried to load the example code, changing only the size (to match my screen). I used the wiring shown here (https://learn.adafruit.com/adafruit-sha ... out/wiring ). Here is another code I tried for the display:
#include <Adafruit_GFX.h>
#include <Adafruit_SharpMem.h>
#define SHARP_SCK  13
#define SHARP_MOSI 11
#define SHARP_SS   10
Adafruit_SharpMem display(SHARP_SCK, SHARP_MOSI, SHARP_SS, 400,240);
#define BLACK 0
#define WHITE 1
int minorHalfSize; // 1/2 of lesser of display width or height
void setup(void)
  Serial.begin(9600);
  Serial.println("Hello!");
  display.begin();
  display.clearDisplay();
  minorHalfSize = min(display.width(), display.height())/2;
void loop(void)
    // text display tests
    //display.setRotation(1);
    display.setTextSize(16);
    display.setTextColor(BLACK);
    display.setCursor(0,0);
    display.print(44);
    display.refresh();
Here is what shows up on the display:
Does anyone know how to fix this problem?
The screen is not broken, I bought another one and ran into the same issue.
Thank you!
Re: 400x240 Sharp Display - Can't Use Full Screen
This display requires > 12K of RAM just for the frame buffer. The Mega only has 8K of RAM to work with. You will need a processor with more RAM like the ATSAMD21 (M0), ATSAMD51 (M4) or ESP8266.
fredb_394
Post by fredb_394 »
Thank you for your quick answer. I will look into these.
