AdafruitIO Feed - MQTT ERROR: data missing required value
kevinOI
Post by kevinOI »
I've been following the following guide regarding the RockBLOCK 9603 in an attempt to get telemetry from a flight controller to ground control software:
https://learn.adafruit.com/using-the-ro ... m?view=all
I'm able to do all of what's described, except the part involving AdafruitIO webhooks. I've entered the webhook URL as a delivery address in Rock7's admin page, but when data is sent, the feed page shows, as a red notification bar, the error:
MQTT ERROR: error saving data to kevinOI/feeds/rockblock, data missing required value
I have no idea what value it's referring to. Has anyone run into a similar issue?
mikeysklar
Re: AdafruitIO Feed - MQTT ERROR: data missing required value
Post by mikeysklar »
What type of controller are you using in your setup? It would be helfpul to get a better error message from the REPL console. Are you are using a CircuitPython based microcontroller (for example) or the command-line on a Raspberry Pi? Do you see a more detailed error message?
kevinOI
Post by kevinOI »
The flight controller is a Cube Orange, and the error message is being displayed through the "Feeds" page on adafruit IO. There's no command line interface being used at this stage and therefore no CircuitPython or Raspberry Pi. Unless a lower-level interface is available somewhere on Adafruit IO, no more detail is available to me.
adafruit_support_carter
Just to check - when setting up the Delivery Group, did you set the method to HTTP_JSON?
kevinOI
Post by kevinOI »
Apologies for the late response. Yes, I did set the method to HTTP_JSON.
And to be clear here:
That's on the Adafruit IO feeds pages?
Everything looks OK from the Rock7 server point of view? You can check message once logged into your Rock7 account via the "Messages" option in the left hand nav menu. Can select a search date range and then should see a list of messages like this:
Any errors and/or useful info there?
EDIT - also double check the URL you pasted as the Delivery Address on the Rock7 server and make sure it ends with /raw.
I'm pretty sure the missing /raw in the URL is the issue. The guide does not really mention that as required, and the default URL generated by AIO does not include it.
Try just manually editing the URL on the Rock7 server and append /raw to it.
This is the step the guide forgot to mention. There's an option to create the URL with /raw when setting up the webhook on AIO:
kevinOI
Post by kevinOI »
There are no errors on the Rock7 admin page. Everything appears to have been delivered, on that panel.
I did try appending /raw to the end of the URL and this did not appear to make any difference. I will test that again to confirm and let you know.
Yep, please double check and test again.
The original error message:
is because Adafruit IO is looking for and expecting there to be an actual "value" parameter in the incoming response. That *could* be done if Rock7 allowed for more customization of the actual response structure. But there is no such capability and the resulting Rock7 response does not have any "value" parameter. That is why adding /raw is needed. That maps (Adafruit IO does this internally) the entire response blob as being the "value" parameter. Without the /raw, the response is required to have a "value" parameter.
The guide did a poor job of making that known - i.e., needing to add /raw to the URL. I updated it yesterday to hopefully clarify that. Sorry for that confusion.
If it's behaving differently, not working in a new way, different error message, etc. please post updated info here.
kevinOI
Post by kevinOI »
The issue has indeed been resolved. Which is strange, as I'm certain that I tried this the first time, and didn't see any positive change there. In any case, thank you for your assistance.
Cool, glad that fixed it. Could be something got cached somewhere on Rock7 servers and it didn't actually use the updated URL right away, or something like that. But I think the missing /raw in the URL was the only issue here (hopefully).
If you run into anything else, let us know. Good luck with your project!
