Hi folks,
I would like to create a peripheral for a Raspberry Pi that includes USB HID and CANBus. I would like this to be an easily available and integrated breakout board, since I need to whip up a quick prototype. So as I see it, the µC I use must be able to --
* Read GPIOs from a rotary encoder, and represent them as a USB HID interface, similarly to a Rotary Trinkey (https://www.adafruit.com/product/4964).
* Send and receive data via CAN RX/TX pins in conjunction with a CAN transceiver (https://www.adafruit.com/product/5708).
Here's what I've found --
* I am aware of a software CAN implementation for an RP2040 that goes up to 1 Mbps (https://github.com/KevinOConnor/can2040). I don't know if this is of high quality. Is it?
* I tried compiling a simple HID example for an RP2040 board, but the HID-Project headers (https://github.com/NicoHood/HID) tell me, "HID Project can only be used with an USB MCU."
* I know that ESP32 devices support CANBus and have what seems like a pretty decent API that is useable by simply calling the FreeRTOS CAN API from a *.ino file.
* I know that newer ESP32 devices support native USB (via assigned D+/D- pins) and can therefore theoretically act as USB HID peripherals, but I don't know how to program them to act as HID peripherals over that interface, especially since the programming is usually done via a USB/Serial link.
I would really like suggestions on what to use!
Ihab
Arduino programmable µC with CANBus, HID
- ihab
Re: Arduino programmable µC with CANBus, HID
Quick update. I have started using an ESP32S3 dev kit and it works well (sorry if this is not an Adafruit product) --
https://docs.espressif.com/projects/esp ... itc-1.html
The dev kit explicitly has 2 USB ports -- one for programming, labeled "UART", and one connected to the microcontroller's native USB implementation, labeled "USB". I have been able to get a USB HID interface on the latter.
Ihab
Ihab
- ihab
