alarm.sleep_memory out of range
blakebr
Post by blakebr »
Good morning,
I copied this code from the web site (https://learn.adafruit.com/deep-sleep-w ... eep-memory):
import time
import alarm
import board
import supervisor
import microcontroller
8  if not alarm.wake_alarm:
9  # Use byte 5 in sleep memory. This is just an example.
10     alarm.sleep_memory[5] = 0
11 alarm.sleep_memory[5] = (alarm.sleep_memory[5] + 1) % 256
12 print(alarm.sleep_memory[5])
13 while True: pass
I get the following error when run:
  File "code.py", line 10, in <module>
IndexError: index out of range
What am I doing wrong?
Bruce
Adafruit CircuitPython 8.0.5 on 2023-03-31; Raspberry Pi Pico W with rp2040
Board ID:raspberry_pi_pico_w
UID:E6614103E719A637
MAC:28:CD:C1:00:6B:08
boot.py output:
Write to SD Card: True
Write to Flash : False
boot.py Finis
danhalbert
Re: alarm.sleep_memory out of range
Post by danhalbert »
The RPI Pico and Pico W boards don't have sleep memory implemented yet, sorry.
dastels
Post by dastels »
That example was written for the ESP32-S2, not the RP2040 which accounts for the difference.
From shared-bindings/alarm/SleepMemory.c:
//| class SleepMemory:
//|     """Store raw bytes in RAM that persists during deep sleep.
//|     The class acts as a ``bytearray``.
//|     If power is lost, the memory contents are lost.
//|     Note that this class can't be imported and used directly. The sole
//|     instance of :class:`SleepMemory` is available at
//|     :attr:`alarm.sleep_memory`.
//|     **Limitations:** Not supported on RP2040.
So you won't be able to use sleepmemory.
blakebr
Post by blakebr »
Dan, Dave,
Thanks for the replies.
Dan, "yet" gives me hope.
Bruce
danhalbert
I am going to see if it's easy to do. How much sleep memory do you need?
blakebr
Post by blakebr »
Dan,
At first blush, I would say the same as NVM, 0x1000 bytes. Any more than that would be best implemented with external FRAM or EEPROM. I would expect sleep_memory will have a life span, but better than NVM. If not so, there is not much point in sleep_menory, the user may as well go for FRAM at the start.
Bruce
FYI, I am testing an FRAM chip and am at 4,200,000 Write/reads so far.
danhalbert
I implemented a 256-byte sleep memory on RP2040. Here are the artifacts if you would like to test:
https://github.com/adafruit/circuitpyth ... 5040174390
On the RP2040, RAM is not powered down during sleep. So this is simply a reserved section of RAM that doesn't get zero'd out on startup.
blakebr
Post by blakebr »
Dan,
WOW, that was fast. I will try it out as soon as we get home from grocery shopping.
I was never warned about this grocery thing!!!
Bruce
blakebr
Post by blakebr »
Dan,
You over estimate my abilities. I don't know what to do with artifacts. I assume compile the OS with them. I have not jumped into that puddle yet. Will the feature appear in an upcoming Alpha version?
Bruce
danhalbert
Just download the .zip file for your board and unzip it. Inside is a .UF2 you can test.
blakebr
Post by blakebr »
Dan,
Thank you, works as described.
Is the reserved 256 bytes going to be a permanent part of the CP 8.1.x build from now on?
Can the reservation of those 256 bytes be turned off to recover those bytes?
Bruce
danhalbert
It will be in all RP2040 builds after 8.1.0. A custom build could be made to turn it off. I made it only 256 bytes to not affect the RAM usage materially.
blakebr
Post by blakebr »
Dan,
After 8.1.0... Good choice on size.
Bruce
