I am looking to combine 3 of these small “Incductive Coil Wireless LEDs” kits using only one power supply. For one it says to use a 5v power supply...but, would the same power supply be enough for three of these kits? Ultimately I just want one power supply with one plug (not three). What is the proper power supply (and is there anything else I’ll need to make this work as I mentioned)? I thank you in advance for your time and help and I look forward to hearing from you soon.
Best regards,
Chris
Power supply for small “Inductive coil Wireless LEDs kit”
- LosCA
Re: Power supply for small “Inductive coil Wireless LEDs kit”
A single 5V power supply can power multiple inductive loops. You just need a power supply that can provide enough current for them.
A 2A wall adapter should work.
- LosCA
Thank you Mike. I appreciate your help!
