Arduino IDE showing trinket m0 as pirkey
- TopHatRaver
I have my Trinket M0 connected to my computer and it is recognized. In the Arduino IDE I select the Trinket M0 as my board and then port 4. But under port 4 it shows 2 boards. I upload my sketch to the Trinket M0 but once it connects then disconnects, it now shows it as the pIRKey board in stead. Then I have to go through the same process over - select the Trinket M0, set the port, upload sketch. Is there some way to NOT have it recognized as the pIRKEY?
- Screenshot 2023-05-21 194701.png (71.6 KiB) Viewed 153 times
- dastels
Re: Arduino IDE showing trinket m0 as pirkey
Weird. I'm seeing what I can find out.
- adafruit2
its just how the IDE tries to recognize the board. totally not harmful, can keep using it as is :)
what version/OS of the IDE are you using?
- TopHatRaver
I'm using -
Version: 2.1.0
Date: 2023-04-19T15:31:10.185Z
CLI Version: 0.32.2
Copyright © 2023 Arduino SA
If I leave it as pIRKEY and upload, the sketch doesn't work. So I have to change it to Trinket M0 and upload. Once my computer connects to the Trinket and you hear the USB connect/disconnect chime, it reconnects as pIRKEY again. So its a real pain having to change it every time it reconnects.
- adafruit2
could you use v1.8 IDE for now or do you need 2.1? something must have changed in the IDE...
- TopHatRaver
- hathach
we have fixed the issue, and making PR to release SAMD core. Once the PR https://github.com/adafruit/arduino-boa ... x/pull/106 is merged, it will take a few hours for 1.7.12 to come online.
- TopHatRaver
Thank you so much for the quick response and fix!
