I purchased 2.3 128x32 monochrome oled. Following the SPI wiring diagram correctly I got no results from the ssd1305test. no errors on screen for code and all wires are connected according to specifications.
The oled won't turn on or run script. It may be a faulty oled could i get a replacement for the price i payed.
Thank you
Re: 2.3 128x32 monochrome oled
Please post some photos showing all of your soldering and connections.
- customer123
File too large
How do you want to recieve the images
If your photo app does not support resizing there are plenty of free online sites that will do it. 800x600 is a good size to aim for.
- customer123
Okay i believe i added the files
- a2fuq-ihrfd.jpg (18.77 KiB) Viewed 53 times
- a0mb8-300u5.jpg (27.77 KiB) Viewed 53 times
- azjku-o3c6v.jpg (24.88 KiB) Viewed 53 times
- customer123
I hope this is all the photos
- aerv7-l768c.jpg (27.83 KiB) Viewed 53 times
- customer123
only getting 3 at a time
- au4ge-spuro.jpg (30.67 KiB) Viewed 53 times
- atirn-ukbnu.jpg (29.13 KiB) Viewed 53 times
- ap20l-uos2p.jpg (28.14 KiB) Viewed 53 times
- customer123
this is my setup
Looks like you are missing a couple of connections there:
* Connect Pin #8 (DIN) to digital #11 via the level shifter (green wires)
* Connect Pin #15 (CS) to digital #10 via the level shifter (yellow wires)
Also, it looks like you might have the level shifter chip reversed. The notch or dot indicates pin 1 on the chip and should be facing to the right as in the photo below:
- customer123
the image quality does not show it but im certain it's all connected and properly orientated. I've rewired this multiple times according to all instruction provided.
No result or indication of it working.
Could it be faulty do i need a new one?
Try reversing the chip. It will not work connected backwards.
- customer123
the image quality does not show it but the level shifter u notch is facing the right. As per the diagam Starint g from lcd pin din and cs connected via level shifter with there corrisponding wiring continue to the digitial pins from the repective pins to the left on the level shifter
I wire this multiple times all to insturction provided
I need a pretested new one
Yes, one of the photos does show the missing connections.
Unfortunately, these displays are out of stock. If you contact [email protected] with your order information and a link to this thread we can issue a refund.
