I recently received this kit (1), below, assembled the pi zero into the case and installed the Adafruit Mini PiTFT screen (2), below. I then installed the pi-hole software via ssh and it is up and running.
However, the screen in not active. I understand that I need to install the python software and code to make the screen display information that would normally be shown on an HDMI monitor, and the stats from the running pi-hole.
I found the tutorial below (3), but it is for an older pi-hole kit using an OLED display. If I follow (3), will it work with the Adafruit Mini PiTFT display? Or do I need a different tutorial link to correctly install the python software for this Mini PiTFT display on the newer pi-hole pi zero W ?
(1) Mini Color PiTFT Ad Blocking Pi-Hole Kit
https://www.adafruit.com/product/4475
(2)Adafruit Mini PiTFT - 135x240 Color TFT Add-on for Raspberry Pi
https://www.adafruit.com/product/4393
(3) Pi Hole Ad Blocker with Pi Zero W
https://learn.adafruit.com/pi-hole-ad-b ... -pi-zero-w
Rob
- Franklin97355
Re: Mini Color PiTFT Ad Blocking Pi-Hole Kit
The learn article looks like it is using the same display you have. Can you post pictures of your setup?
