DS3231 RTC Interrupt Time Display Problem
Alandinho10
Post by Alandinho10 »
Hello Everyone,
This code is printing the current time and temperature in Fahrenheit no problem, but the time in milli seconds is not going up even when I have the SQW wired to pin 32. Here is the code and output below:
Code:
#include "RTClib.h"
RTC_DS3231 rtc;
int interrupt_pin = 32;
int current = 0;
int milliseconds = 0;
void IRAM_ATTR function()
    milliseconds = millis() - current;
    current = millis();
  Serial.begin(9600);
  rtc.begin();
  pinMode(interrupt_pin, INPUT_PULLUP);
  attachInterrupt(interrupt_pin, function, FALLING);
  // Set the time to 11:30 AM
  rtc.adjust(DateTime(__DATE__, __TIME__));
  rtc.adjust(DateTime(0, 0, 0, 11, 20, 0));  // Set the desired time here
  DateTime now = rtc.now();
  // Display time
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.print('.');
  Serial.print(milliseconds);
  float temperatureC = rtc.getTemperature();
  float temperatureF = (temperatureC * 9 / 5) + 32; // Convert Celsius to Fahrenheit
  Serial.print(" ");
  Serial.println(temperatureF);
Output:
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:42.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
11:20:43.0 74.30
Re: DS3231 RTC Interrupt Time Display Problem
The square wave output defaults to off at power up. You need to enable it: https://adafruit.github.io/RTClib/html/ ... a72dae1f72
Alandinho10
Great and what is the default output Square wave is it 1000hz?
The mode options are defined in the header file:
https://github.com/adafruit/RTClib/blob ... c/RTClib.h
/** DS3231 SQW pin mode settings */
enum Ds3231SqwPinMode {
  DS3231_OFF = 0x1C,            /**< Off */
  DS3231_SquareWave1Hz = 0x00,  /**<  1Hz square wave */
  DS3231_SquareWave1kHz = 0x08, /**<  1kHz square wave */
  DS3231_SquareWave4kHz = 0x10, /**<  4kHz square wave */
  DS3231_SquareWave8kHz = 0x18  /**<  8kHz square wave */
Return to “Arduino”
