PCF8523 not working with Itsy Bitsy M4 Express
AC5Me
Post by AC5Me »
Hi. I'm using the instructions from the Adafruit website with the recommended RTClib library but I'm seeing strange behavior. The RTC will set the time but after a power cycle it will lose it even though the coin cell battery is showing 3V0.
Any tips?
adafruit_support_carter
Re: PCF8523 not working with Itsy Bitsy M4 Express
Are you running CircuitPython or Arduino on the Itsy?
AC5Me
Post by AC5Me »
Arduino IDE and bootloader updated. Thanks.
If you run this the example sketch back to back, without a power cycle, it only shows the "RTC is NOT initialized, let's set the time!" on the first run? But if you then power cycle, the message comes back?
This is the example sketch for ref:
https://github.com/adafruit/RTClib/blob ... cf8523.ino
which is the same one mentioned in the guide:
https://learn.adafruit.com/adafruit-pcf ... th-arduino
AC5Me
Post by AC5Me »
My apologies, it turned out I was still using the old declaration from the ds1307. Which was kinda working, close but not close enough!
Jim
Ah, cool. No worries. Just glad it was something simple.
Return to “Itsy Bitsy Boards”
