clear a specific matrix area ???
tolisn
Post by tolisn »
Hi.
I am using the matrix portal to drive 2 led matrix screens (64x32 each). The total configuration is 64x64 . On the top screen I print the time (from an NTP server) and on the bottom screen I print some values from Thingspeak (TS).
The time is updated every second whereas the TS values are updated every 15 seconds.
The problem is the by using the matrix.fillscreen(0) to clear the screen for the time update the TS values are also deleted nad are shown again after 15 seconds when they are updated.
Is there anyway to make the matrix.fillscreen command to clear a specific section of the matrix and not all the matrix or maybe there is another command that I'm missing ?
Ps. I'm using the Arduino IDE to compile.
This is the code so far
#include <Adafruit_Protomatter.h>
#include <Fonts/FreeSerifItalic9pt7b.h> // Large friendly font
#include <Fonts/TomThumb.h> // small font
#include <WiFi.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include "secrets.h"
#include "ThingSpeak.h"
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#if defined(_VARIANT_MATRIXPORTAL_M4_) // MatrixPortal M4
  uint8_t rgbPins[]  = {7, 8, 9, 10, 11, 12};
  uint8_t addrPins[] = {17, 18, 19, 20, 21};
  uint8_t clockPin   = 14;
  uint8_t latchPin   = 15;
  uint8_t oePin      = 16;
#endif
Adafruit_Protomatter matrix(
  64,          // Width of matrix (or matrices, if tiled horizontally)
  6,           // Bit depth, 1-6
  1, rgbPins,  // # of matrix chains, array of 6 RGB pins for each
  4, addrPins, // # of address pins (height is inferred), array of pins
  clockPin, latchPin, oePin, // Other matrix control pins
  true,       // No double-buffering here (see "doublebuffer" example)
  -2);         // Row tiling: two rows in "serpentine" path
char ssid[] = SECRET_SSID;   // your network SSID (name)
char pass[] = SECRET_PASS;   // your network password
int keyIndex = 0;            // your network key Index number (needed only for WEP)
WiFiClient client;
// Weather station channel details
unsigned long weatherStationChannelNumber = SECRET_CH_ID_WEATHER_STATION;
const char* readAPIKey = SECRET_READ_APIKEY; // your ThingSpeak Read API Key
int statusCode = 0;
int field[8] = {1, 2, 3, 4, 5, 6, 7, 8};
int OutTemp;         // Field 1
float pressure;      // Field 2
int percentHumid;    // Field 3
float BattVolt;      // Field 4
float PanelVoltage;  // Field 5
float PanelCurrent;  // Field 6
const char* ntpServer = "pool.ntp.org";
const long  utcOffsetInSeconds = 0;
WiFiUDP udp;
NTPClient timeClient(udp, ntpServer, utcOffsetInSeconds);
  Serial.begin(115200);      // Initialize serial
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo native USB port only
  ThingSpeak.begin(client);  // Initialize ThingSpeak
  // Connect or reconnect to WiFi
  if (WiFi.status() != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(SECRET_SSID);
    while (WiFi.status() != WL_CONNECTED) {
      WiFi.begin(ssid, pass); // Connect to WPA/WPA2 network. Change this line if using an open or WEP network
      Serial.print(".");
      delay(5000);
    Serial.println("\nConnected");
  timeClient.begin();
  timeClient.update();
  // Initialize matrix...
  ProtomatterStatus status = matrix.begin();
  Serial.print("Protomatter begin() status: ");
  Serial.println((int)status);
  if (status != PROTOMATTER_OK) {
    // DO NOT CONTINUE if matrix setup encountered an error.
    while (1);
  matrix.fillScreen(0); // clear the screen
  matrix.setCursor(5, 15); // set the cursor position
  matrix.setFont(&TomThumb); // Use nice bitmap font
  matrix.setTextColor(RED); // set the text color
  matrix.show(); // and show it
  static unsigned long previousTimeMillis = 0;
  unsigned long currentTimeMillis = millis();
  if (currentTimeMillis - previousTimeMillis >= 1000) {
    previousTimeMillis = currentTimeMillis;
    String formattedTime = timeClient.getFormattedTime();
    matrix.setCursor(0, 10); // set the cursor position
    matrix.setFont(&TomThumb); // Use small font
    matrix.setTextColor(WHITE); // set the text color
    matrix.print(formattedTime); // display the time
  static unsigned long previousTSUpdateMillis = 0;
  unsigned long currentTSUpdateMillis = millis();
  if (currentTSUpdateMillis - previousTSUpdateMillis >= 15000) {
    previousTSUpdateMillis = currentTSUpdateMillis;
    statusCode = ThingSpeak.readMultipleFields(weatherStationChannelNumber, readAPIKey);
    if (statusCode == 200) {
      // Fetch the stored data
      OutTemp = ThingSpeak.getFieldAsInt(field[0]); // Field 1
      pressure = ThingSpeak.getFieldAsFloat(field[1]); // Field 2
      percentHumid = ThingSpeak.getFieldAsInt(field[2]); // Field 3
      BattVolt = ThingSpeak.getFieldAsFloat(field[3]); // Field 4
      PanelVoltage = ThingSpeak.getFieldAsFloat(field[4]); // Field 5
      PanelCurrent = ThingSpeak.getFieldAsFloat(field[5]); // Field 6
      // Display on the matrix
      matrix.setCursor(0, 38); // set the cursor position
      matrix.print("Out Temp: " + String(OutTemp) + "°C"); // print the value
      matrix.setCursor(0, 45); // set the cursor position
      matrix.setTextColor(GREEN); // set the text color
      matrix.print("Humidity: " + String(percentHumid) + " %"); // print the value
      matrix.setCursor(0, 52); // set the cursor position
      matrix.setTextColor(BLUE); // set the text color
      matrix.print("Pressure: " + String(pressure)); // print the value
      matrix.setCursor(0, 59); // set the cursor position
      matrix.setTextColor(CYAN); // set the text color
      matrix.print("Batt. Volt: " + String(BattVolt) + " V"); // print the value
    else {
      Serial.println("Problem reading channel. HTTP error code " + String(statusCode));
dastels
Re: clear a specific matrix area ???
Post by dastels »
Have you tried matrix.drawRect with a color of 0x000000?
tolisn
Post by tolisn »
So instead of using the fillscreen function I should draw a filled rectangle over the area, correct? I will try it and see how it goes. I hope the rectangle draws quickly.
dastels
Post by dastels »
That was my first thought based on looking through the code.
