Hello all, I am not good in programming but want to make these kind of effect on the neopixel strip so need help to make these effects. I am using 50 leds right now but will increase to 100 or 150.
I put a youtube link of the effects i need so you can see the effect.
https://www.youtube.com/watch?v=eDyeuj54DeU
Theater chase neopixel effects
- dastels
Re: Theater chase neopixel effects
You don't say what board/language you are using, but I would start by looking at the CircuitPython LED animation library https://learn.adafruit.com/circuitpython-led-animations.
Reason: typo
Reason: typo
- kaku_hm
sorry about that ,
currently i am using Adafruit_NeoPixel.h library and arduino uno board will use esp8266 in future.
I am willing to make these effects in a function so i can call them whenever needed.
- dastels
OK, you're using C++.
There are plenty of NeoPixel projects in the learning guides: https://learn.adafruit.com/search?q=ard ... 0animation Some of tyhoseare in CircuitPython (even with the arduino keyword). You might get some ideas from them.
- kaku_hm
I modified this code but couldn't reached my desire output, now this gives output only in RED color but i want each group with different color and one more thing the 1st ,6st,11th,16th,21th leds should be OFF after restarting the loop but it is not going OFF.
Need Help
Need Help
#include <FastLED.h>
// How many leds in your strip?
#define NUM_LEDS 24
#define DATA_PIN 6
//#define CLOCK_PIN 13
// Define the array of leds
CRGB leds[NUM_LEDS];
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
theaterChase(CRGB::Red, 80);
void theaterChase(CRGB color, uint8_t wait) {
for (int j = 0; j < 10; j++) { // do 10 cycles of chasing
for (int q = 0; q < 5; q++) {
for (int i = 0; i < NUM_LEDS; i = i + 5) {
leds[i+q] = color; // turn every third pixel on
FastLED.show();
delay(250);
FastLED.clear(); // clear all pixel data
FastLED.show();
- code output.gif (520.88 KiB) Viewed 225 times
Reason: Please use code tags for embedded code
- dastels
Everything looks to be functional, and you are off to a good start with the code. Keep working on it.
