Metro M7 wifi
- richpaul6806
Metro M7 wifi
I tried to follow the "CircuitPython WiFi" section of the metro M7 guide to confirm wifi connection and got: TimeoutError: ESP32 timed out on SPI select. Everything appears to be configured correctly. Any thoughts?
- mikeysklar
Re: Metro M7 wifi
I pulled my Metro M7 out of the shrink wrap and was able to run the CircuitPython WiFi example code.
Here is what I did:
1) Install CircuitPython 8.2.0-beta0
2) Install the three necessary libraries from the latest CP-8.x MPY drop.
3) setup the settings.toml with my WIFI_SSID and WIFI_PASSWORD.
4) Update code.py with the stock WiFi example no modification required.
5) Watched console:
Here is what I did:
/adafruit_bus_device
/adafruit_esp32spi
adafruit_requests.mpy
5) Watched console:
code.py | 8.2.0-beta.0code.py | 8.2.0-beta.0ESP32 SPI webclient test
ESP32 found and in idle mode
Firmware vers. bytearray(b'1.7.4\x00')
MAC addr: ['0x78', '0xd2', '0x1f', '0xda', '0xd4', '0xd4']
sesame mesh RSSI: -52
bolo5 RSSI: -54
sesame mesh RSSI: -61
sesame mesh RSSI: -70
Connecting to AP...
Connected to sesame mesh RSSI: -51
My IP address is 192.168.86.33
IP lookup adafruit.com: 104.20.39.240
Ping google.com: 20 ms
Fetching text from http://wifitest.adafruit.com/testwifi/index.html
This is a test of Adafruit WiFi!
If you can read this, its working :)
Fetching json from http://api.coindesk.com/v1/bpi/currentprice/USD.json
{'time': {'updated': 'May 24, 2023 21:20:00 UTC', 'updatedISO': '2023-05-24T21:20:00+00:00', 'updateduk': 'May 24, 2023 at 22:20 BST'}, 'disclaimer': 'This data was produced from the CoinDesk BANNED Price Index (USD). Non-USD currency data converted using hourly conversion rate from openexchangerates.org', 'bpi': {'USD': {'code': 'USD', 'description': 'United States Dollar', 'rate_float': 26391.5, 'rate': '26,391.4645'}}}
Done!
- richpaul6806
Re: Metro M7 wifi
Metro M7 should have those 3 libraries as modules internal to the board.If you enter repl and type help ('modules') you can see them there. I think this tutorial is just a copy/paste from their other boards where that step is necessary. Regardless, I gave it a shot with those libraries manually added. Same result.
- mikeysklar
Re: Metro M7 wifi
Have you started fresh with the firmware erase image?
Which version of CircuitPython are you running?
Downloads --> Files (last one)
- richpaul6806
Re: Metro M7 wifi
I successfully erased the firmware and decided to try again. Online tool still didnt work and neither did esptool so I tried the circuitpython code found at viewtopic.php?p=973521#p973521 again. For some reason I had to flip rx and tx pin order on the UART command (I dont remember doing that before) but I got it installed again and it appears to be working. Wish I knew what the issue was but at least it is working now.
- mikeysklar
Re: Metro M7 wifi
This is helpful. Since the board is so new the docs and install scripts can use some tweaking.
I'll take a look at the rx/tx pins in the circuitpython script used for the AirLift update to make that easier for others.
The pins are backwards in the example code according to the docs.
I was able to also confirm the CP based update method worked on my board with the above change. I updated the guide notes script.
As you suggested. This needs to be changed:classbusio.UART(tx: microcontroller.Pin | None = None, rx: microcontroller.Pin | None = None, *, rts: microcontroller.Pin | None = None, cts: microcontroller.Pin | None = None, rs485_dir: microcontroller.Pin | None = None, rs485_invert: bool = False, baudrate: int = 9600, bits: int = 8, parity: Parity | None = None, stop: int = 1, timeout: float = 1, receiver_buffer_size: int = 64)
uart = busio.UART(rx, tx, baudrate=115200, timeout=1)
uart = busio.UART(tx, rx, baudrate=115200, timeout=1)
code.py | 8.1.0code.py | 8.1.0ESP32 Nina-FW
Resetting
Synced
Found: ESP32
MAC ADDR: ['0xd4', '0xd4', '0xda', '0x1f', '0xd2', '0x78']
Writing NINA_W102-1.7.4.bin w/filesize: 1159168
Erase size 1159168, num_blocks 2264, size 512, offset 0x0000
Took 2.32s to erase 2264 flash blocks
Writing at 0x0011ae00... (100 %)Took 46.17s to write 1159168 bytes
Verifying MD5sum 80c2dfd8ad2e97b2c32899382860acb1
Resetting
