ESP32-S3 Read analog channel with WiFi Connected
Mark_Aerobat
Post by Mark_Aerobat »
I am having an issue with reading an analog channel when connected to WiFi and publishing to Adafruit IO. To debug the issue I used the Adafruit Random Number/Neopixel sample code and modified it to read two analog channels and publish the values to Adafruit IO. Here is the code.
# SPDX-FileCopyrightText: 2021 Ladyada for Adafruit Industries
# SPDX-FileCopyrightText: 2022 Kattni Rembor for Adafruit Industries
import time
import ssl
from random import randint
import microcontroller
import socketpool
import wifi
import board
import neopixel
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_io.adafruit_io import IO_MQTT
from analogio import AnalogIn
analog_in_5 = AnalogIn(board.D5)
analog_in_6 = AnalogIn(board.D6)
try:
    from data import secrets
except ImportError:
    print("WiFi and Adafruit IO credentials are kept in secrets.py - please add them there!")
    raise
# Add your Adafruit IO Username and Key to secrets.py
# (visit io.adafruit.com if you need to create an account,
# or if you need to obtain your Adafruit IO key.)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
# WiFi
try:
    print("Connecting to %s" % secrets["ssid"])
    wifi.radio.connect(secrets["ssid"], secrets["password"])
    print("Connected to %s!" % secrets["ssid"])
# Wi-Fi connectivity fails with error messages, not specific errors, so this except is broad.
except Exception as e:  # pylint: disable=broad-except
    print("Failed to connect to WiFi. Error:", e, "\nBoard will hard reset in 30 seconds.")
    time.sleep(30)
    microcontroller.reset()
# Initialise NeoPixel
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.3)
# Define callback functions which will be called when certain events happen.
def connected(client):
    print("Connected to Adafruit IO!  Listening for NeoPixel changes...")
    # Subscribe to Adafruit IO feed called "neopixel"
    client.subscribe("neopixel")
def message(client, feed_id, payload):  # pylint: disable=unused-argument
    print("Feed {0} received new value: {1}".format(feed_id, payload))
    if feed_id == "neopixel":
        pixel.fill(int(payload[1:], 16))
# Create a socket pool
pool = socketpool.SocketPool(wifi.radio)
# Initialize a new MQTT Client object
mqtt_client = MQTT.MQTT(
    broker="io.adafruit.com",
    username=secrets["aio_username"],
    password=secrets["aio_key"],
    socket_pool=pool,
    ssl_context=ssl.create_default_context(),
# Initialize Adafruit IO MQTT "helper"
io = IO_MQTT(mqtt_client)
# Set up the callback methods above
io.on_connect = connected
io.on_message = message
try:
    # If Adafruit IO is not connected...
    if not io.is_connected:
        # Connect the client to the MQTT broker.
        print("Connecting to Adafruit IO...")
        io.connect()
    # Explicitly pump the message loop.
    io.loop()
    # Publish when first booted
    io.publish("random-boot", "BOOT")
    # Adafruit IO fails with internal error types and WiFi fails with specific messages.
    # This except is broad to handle any possible failure.
    print("Failed to get or send data, or connect. Error:", e,
    time.sleep(30)
timestamp = 0
while True:
    number_5 = analog_in_5.value
    time.sleep(0.1)
    number_6 = analog_in_6.value
    time.sleep(0.1)
    try:
            io.connect()
        io.loop()
        # Print and publish analog readings to Adafruit IO every 10 seconds.
        if (time.monotonic() - timestamp) >= 10:
            #random_number = "{}".format(randint(0, 255))
            #print("Current 'random' number: {}".format(random_number))
            print(number_5, number_6)
            io.publish("analog-in-5", number_5)
            io.publish("analog-in-6", number_6)
            timestamp = time.monotonic()
        time.sleep(30)
When I run this code it initially starts ok.
But then crashes with the following error.
Is it possible to read from the analog channel on an ESP32-S3 while connected to WiFi and publishing to Adafruit IO? Any ideas what the issue could be?
brubell
Learn User Page
Re: ESP32-S3 Read analog channel with WiFi Connected
Post by brubell »
It should be fine, the pinouts on the learning guide don't mark any issues with these pins and WiFi on the ESP32-S3.
I am going to move this topic to the CircuitPython forum to see if any experts there can assist.
