Pi Pico - nearly empty mainloop at 30 kHz only?
Greg0815
Post by Greg0815 »
i come from 8bit Atmel world with C and also did some Audio/Midi stuff with Teensy and Arduino. Now i started with a Raspberry Pico and CircuitPy hooking up midi, neopixel, a button and some LEDs from the offical examples and tutorials. Everything working as expected but ... there must be something i did not understand right yet so please point me in the right direction.
My problem: the mainloop looks extremely slow to me. No delays, time-lib is not even imported. With midi (from official example) the mainloop runs at 3 kHz. Without all the midi-stuff and just toggling one LED it's at 30 kHz. Example:
import board
import digitalio
led_3 = digitalio.DigitalInOut(board.GP19)
led_3.direction = digitalio.Direction.OUTPUT
while True:
    if led_3.value == 1:
        led_3.value = 0
    else:
        led_3.value = 1
Hm, 30 kHz is what my old Atmega8 (8MhZ crystal) was running at WITH lots of midi-parsing, ADC-reading, 4051-switching plus buttons, LEDs and logic.
Is the CircuitPy framework eating up all the performance from the 133MHz board? Maybe my Raspberry has an issue?
thank you for bringing some light to my old brain
Gregor
slight
Re: Pi Pico - nearly empty mainloop at 30 kHz only?
Post by slight »
Hi Gregor,
how did you measure the timing?
as CircuitPython is an interpreted language - and the interpretation is done on this little micro-controller it is *normal* that the resulting speed is *slow*.
for the most beginner use-cases it is fast enough... ;-)
i currently have no osci on hand - so i can not tell how fast things move in real -
i just run this speedtest code (orig. from another project therefore way more complicated then needed...):
# SPDX-FileCopyrightText: 2023 s-light.eu Stefan Krüger
import time
import board
import digitalio
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
def speed_test(fn, msg, count=1000):
    print("{} speed test running..".format(msg))
    start = time.monotonic()
    for i in range(count):
        fn()
    end = time.monotonic()
    duration = (end - start) / count
    duration_ms = duration * 1000
    result = {
        "msg": msg,
        "duration_ms": duration_ms,
    print(
        "'{}'  needs {:10.3f}ms/call".format(
            result["msg"],
            result["duration_ms"],
    return result
def print_results(speed_tests):
    msg_max_length = max(len(x["msg"]) for x in speed_tests)
    # print(msg_max_length)
    for test in speed_tests:
        msg_template = (
            "'{:<" + "{}".format(msg_max_length + 5) + "}'  needs {:10.3f}ms/call"
        print(
            msg_template.format(
                test["msg"],
                test["duration_ms"],
print("\n" * 20)
speed_tests = []
if hasattr(board, "DISPLAY"):
    import displayio
    print("deactivate display..")
    board.DISPLAY.auto_refresh = False
    board.DISPLAY.root_group = displayio.Group()
def toggle_led():
    led.value = not led.value
speed_tests.append(
    speed_test(
        toggle_led,
        msg="toggle_led",
        count=100000,
    print("activate display..")
    board.DISPLAY.auto_refresh = True
    board.DISPLAY.root_group = displayio.CIRCUITPYTHON_TERMINAL
print("\n" * 20)
time.sleep(1)
time.sleep(1)
print("done...")
it results in
0;🐍Wi-Fi: off | Done | 8.0.5soft reboot
main.py output:
0;🐍Wi-Fi: off | main.py | 8.0.5
toggle_led speed test running..
'toggle_led'  needs      0.010ms/call
activate display..
'toggle_led     '  needs      0.010ms/call
done...
Code done running.
on my Adafruit ESP32-S3 Reverse TFT Feather
(ESP32-S3 Dual Core 240MHz Tensilica processor)
0.01ms/call würde bei mir wohl so 100 MHz ergeben...
das erscheint mir schnell ;-)
tannewt
Post by tannewt »
I clocked the RP2040 at ~90khz with this blinky code.
import digitalio
import board
led.switch_to_output()
while True:
    led.value = True
    led.value = False
The programming paradigm is pretty different due to this overhead. (The benefit is the faster iteration time.) Usually you'll want to rely on CP to do timing sensitive computation. If you find another piece of code that is too slow, then you can add a c module to do it.
slight
Post by slight »
with my speedtest setup i get
'toggle_led      '  needs     0.0096ms/call
'toggle_led2     '  needs     0.0092ms/call
so i think at this point the overhead of calling a function is big..
retesting with this code
(eliminated the function call)
# SPDX-FileCopyrightText: 2023 s-light.eu stefan krüger
import time
import board
import digitalio
msg_template = "'{:<10}'  needs {:10.4f}ms/call"
count = 100000
    import displayio
print(msg_template.format("led_blink1", duration_ms))
    led.value = True
    led.value = False
print(msg_template.format("led_blink2", duration_ms))
print("done...")
results in
'led_blink1'  needs     0.0062ms/call
'led_blink2'  needs     0.0058ms/call
so it seems the function call needs about
0.0096ms/call - 0.0062ms/call = ~3,4 us
Greg0815
Post by Greg0815 »
Thank you very much for the replies. For speed measuring i simply put an oscilloscope probe on the led pin. I was a bit confused about the speed first while playing around with the midi library. Many incoming data trunks were not forwarded to the serial plotter, it looked like they were simply 'ignored'. I first thought the whole "Pico + CircuitPy for Midi" platform is to 'slow'. The reason was: i used a Yamaha DX7II keyboard which permanently spits out Active sensing messages. Somehow it corrupted the midi data parsing. With another keyboard (not sending active sensing) it worked.
I did not know about the option to implement C-parts in CircuitPy, interesting. I realize i still have a lot to learn :-)
