ADXL375 maximum polling rate
- richpaul6806
Re: ADXL375 maximum polling rate
I am reading the bits from starting at D0-D3 going from right to left but writing them from D3-D0 going left to right
Your program is reading the 4 bits in the same order as you wrote them. But you are writing just the low-order 4 bits of the register and then reading back and printing the entire 8 bit register.
The low order 4 bits are just what you wrote: 1101 == 0xD == 13
The high order 4 bits are all zero. So you are reading back: 00001101 == 0x0D == 13
- richpaul6806
isnt the code RWBits(4, rate_register, 0) telling the program to start at bit 0 and write the next 4 bits(right to left)?
It is defining a 4-bit wide field with the low-order bit at position 0.
https://docs.circuitpython.org/projects ... t/api.html
Parameters
num_bits (int) – The number of bits in the field.
register_address (int) – The register address to read the bit from
lowest_bit (int) – The lowest bits index within the byte at register_address
register_width (int) – The number of bytes in the register. Defaults to 1.
lsb_first (bool) – Is the first byte we read from I2C the LSB? Defaults to true
signed (bool) – If True, the value is a “two’s complement” signed value. If False, it is unsigned.
- richpaul6806
Ah ok. So it is counting right to left to get the block, but once the block is set we read and write left to right. Seems like a backwards way of organizing everything but I'm sure there is some higher level reasoning for it.
