Hi all, whenever I flash some .UF2 file to FEATHERBOOT, the device reboots but the Neopixel will blaze white and not turn off. This was before and after I flashed the recent bootloader 3.15.0. And I cannot turn it off using the Neopixel library in my sketch. See photo.
Any idea why?
Thank you!
Feather M4 Express: Neopixel blazes after flashing
- hmilz
- IMG_20230528_085932-s.jpg (27.38 KiB) Viewed 74 times
- mikeysklar
Re: Feather M4 Express: Neopixel blazes after flashing
The Feather M4 has a NEOPIXEL pin (pin 8) you can use the name or number to reference it. Is that what your Arduino code is using? Can you post the code you are running?
- hmilz
Thank you for the reply, but none of my code is involved in the neopixel blazing. This happens immediately after copying _any_ UF2 file to FEATHERBOOT (in this case, with uf2conv.py), apparently before any sketch begins to run.
- mikeysklar
I'll try it on my Feather M4 Express.
- mikeysklar
I'm unable to reproduce the white light with the standard Adafruit bootloader and images.
What is type of image are you building with the custom UF2's?
