Adafruit has several boards that host the RFM 95 chip but they all seem to lack Lorawan v3 support. I bought these under the assumption that they were compatible.
https://www.adafruit.com/product/4074
Is there a plan to provide v3 support? If not for a gateway, it would be nice to have end device support through CircuitPython as there are many gateway implementations out there unlike end devices. Thanks!
Lorawan V3 support
- mikeysklar
Re: Lorawan V3 support
The guide for using the LoraWAN with Adafruit boards starts with this:
https://www.thethingsnetwork.org/forum/ ... rted/31117This guide is deprecated and is no longer possible! Single-channel packet forwarders no longer work after the Things Network migration to The Things Stack v3. For more information about this decision,
- TI545
That post linked here refers to single channel gateways. I would expect that a feather sensor node should work fine. I have a TTN Indoor Gateway. I'd like to use my feathers with it. I agree my 32u4 LoRa board is too memory limited. But I have hope now that adafruit has a rp2040 LoRa board, lots of RAM. It should run the LMIC library?
- mikeysklar
There are a few different LMIC libraries, but I've seen some success with this one.
