Purchased an HQ Camera Module form Adafruit and it appears to not be working.
Using Raspi 4 2GB with latest 32-bit bullseye.
libcamera-hello finds no camera. Swapped camera cables, reseated multiple times, installed RPI Camera Module 3 on same cable, ROI Cam 3 working fine.
I believe I need an RMA and a new module shipped.
Thank you.
HQ Camera Module Not Working
- mikeysklar
Re: HQ Camera Module Not Working
Here is a short checklist of common issues with the HQ Camera and Bullseye.
1) Make sure you running libcamera-hello locally under x-windows. Not remotely using ssh or through vnc.
2) Enable GLAMUR under raspi-config --> Advanced Settings
3) Modify /boot/config.txt
Change this line to 0.
add this line:
4) Run rpi-update to update the firmware
What was the date of purchase on the HQ Camera from Adafruit?
camera_auto_detect=1
dtoverlay=imx477
- fryerchrisj
1. Ordered HD Camera Module on May 19th with this order number: 3075176-4901994204
2. Tried suggestions; see picture for results (GLAMUR is not an Advanced Option on my Raspi 4 in raspi-config)
3. Suggested edits in /boot/config.txt were made. However, camera_auto_detect=1 was not in the config.txt at all. I tried a few different combinations but see picture.
4. Still no camera detected by libcamera-hello:
$ libcamera-hello
Preview window unavailable
[0:07:45.257018125] [1533] INFO Camera camera_manager.cpp:299 libcamera v0.0.4+22-923f5d70
ERROR: *** no cameras available ***
5. What are my next steps? RMA?
Thank you.
Chris
$ libcamera-hello
Thank you.
Chris
- RPI4HDCAM - Errors2.jpg (997.8 KiB) Viewed 72 times
- mikeysklar
Yes, let's proceed with a RMA. Thank you for trying those configurations and verifying that another model of camera was working.
Please e-mail [email protected] to request a replacement. They will need this forum link and your order#.
Let us know how the replacement works.
