Can't upload onto Itsy Bitsy 32u4
- alphax1987
Im currently trying to upload code onto the Itsy Bitsy 32u4 however it is constantly stating avrdude: ser_open(): can't open device "\\.\COM#": The system cannot find the file specified. I don't know what to do and I already tried to change the wire that is connected to the Itsy Bitsy and changing the COM number.
- blnkjns
Re: Can't upload onto Itsy Bitsy 32u4
Are you working with code that uses the serial monitor? On a 32U4 that can interfere with uploading code.
2 things to try:
double tap reset and check if it goes into another mode
or hit reset exactly on the moment the compiler wants to start with uploading.
2 things to try:
- adafruit_support_carter
By wire, do you mean USB cable?I already tried to change the wire that is connected to the Itsy Bitsy
