I have an older OLED display that I'm driving from both a Feather S3 and ESP32-S3. One of the learning documents for these displays showed a baud rate of 16,000,000 which created a lot of horizontal line artifacts and has a blocky flickering appearance. I tried a bunch of slower values before settling on 640,000, but the results are still not great.
It's been a while since I used this same display with an Arduino based project, but I don't remember any issues.
Any suggestions on how to pick a proper baud rate and what might improve the quality?
https://www.adafruit.com/product/1673
spi = board.SPI()
bus = displayio.FourWire(spi,
command=board.D5,
chip_select=board.D9,
reset=board.D6,
baudrate=640000) # 16000000) # 24000000)
self._display = SSD1351(bus, width=128, height=96)
Display Flicker -- Baudrate
- mikeysklar
Re: Display Flicker -- Baudrate
The SSD1531 chipset this display uses should work at speeds up to 20MHz (20000000) which the Feather S3 or ESP32-S3 should have no trouble driving at that baudrate. Keep the connections short.
Which Adafruit example have you been running?
- moWhite
Thanks for your response. I'm using 3-inch jumper wires and I don't have the SD card wired.
This is the main sample that I used to both wire and code that has the 16,000,000 baudrate set: https://learn.adafruit.com/adafruit-1-5 ... quickstart
I'll try and do a screen shot with the blocking and line artifacts.
