Raspberry pi 3 a+ model a plus pi Wi-Fi issues
Yankstixman
Post by Yankstixman »
Wi-Fi doesn’t work properly. I’ve tried everything, from stronger power supply to different OS installations. The Wi-Fi keeps losing the carrier every minute or two. It seems the hardware is defected Image
mikeysklar
Re: Raspberry pi 3 a+ model a plus pi Wi-Fi issues
Post by mikeysklar »
Did you disable power saving?
check:
sudo iw wlan0 get power_save
temporary between boots:
sudo iw wlan0 set power_save off
permanent:
 sudo /sbin/iw dev wlan0 set power_save off
