Hello all,
I have a student who is using the GPS adafruit breakout successfully with an Arduino, but when she switched to a NodeMCU (ESP8266) we don't get any readings. e.g. "Time: ******".
Is there anything we are not realizing about the ESP/GPS interaction?... HELP!
GPS with ESP8266
- Franklin97355
Re: GPS with ESP8266
What code is she running and how is it connected?
- ridanleffell
Thank you for your help! I am using a NodeMCU, ESP8266 and an ultimate GPS Breakout v3 board. When uploading my code, the GPS bored receives a FIX. Yet, the GPS coordinates are not printing on the consul. However, when using an Arduino, instead of a NodeMCU, the code seems to work. Do you have any advice or suggestions in order to solve this problem?
TX -> Pin 8
RX -> Pin 7
GND -> GND
VIN -> 3v3
Thank you
TX -> Pin 8
RX -> Pin 7
GND -> GND
VIN -> 3v3
Thank you
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
/* Create object named bt of the class SoftwareSerial */
SoftwareSerial GPS_SoftSerial(8, 7);/* (Rx, Tx) *
//SoftwareSerial GPS_SoftSerial(2, 3);/* (Rx, Tx) *
/* Create an object named gps of the class TinyGPSPlus */
TinyGPSPlus gps;
volatile float minutes, seconds;
volatile int degree, secs, mins;
Serial.begin(115200); /* Define baud rate for serial communication */
//Serial.begin(9600); /* Define baud rate for serial communication */
GPS_SoftSerial.begin(9600); /* Define baud rate for software serial communication */
smartDelay(1000); /* Generate precise delay of 1ms */
unsigned long start;
double lat_val, lng_val, alt_m_val;
uint8_t hr_val, min_val, sec_val;
bool loc_valid, alt_valid, time_valid;
lat_val = gps.location.lat(); /* Get latitude data */
loc_valid = gps.location.isValid(); /* Check if valid location data is available */
lng_val = gps.location.lng(); /* Get longtitude data */
alt_m_val = gps.altitude.meters(); /* Get altitude data in meters */
alt_valid = gps.altitude.isValid(); /* Check if valid altitude data is available */
hr_val = gps.time.hour(); /* Get hour */
min_val = gps.time.minute(); /* Get minutes */
sec_val = gps.time.second(); /* Get seconds */
time_valid = gps.time.isValid(); /* Check if valid time data is available */
if (!loc_valid)
Serial.print("Latitude : ");
Serial.println("*****");
Serial.print("Longitude : ");
else
DegMinSec(lat_val);
Serial.print("Latitude in Decimal Degrees : ");
Serial.println(lat_val, 6);
Serial.print("Latitude in Degrees Minutes Seconds : ");
Serial.print(degree);
Serial.print("\t");
Serial.print(mins);
Serial.print("\t");
Serial.println(secs);
DegMinSec(lng_val); /* Convert the decimal degree value into degrees minutes seconds form */
Serial.print("Longitude in Decimal Degrees : ");
Serial.println(lng_val, 6);
Serial.print("Longitude in Degrees Minutes Seconds : ");
Serial.print("\t");
Serial.print(mins);
Serial.print("\t");
if (!alt_valid)
Serial.print("Altitude : ");
else
Serial.println(alt_m_val, 6);
if (!time_valid)
Serial.print("Time : ");
else
char time_string[32];
sprintf(time_string, "Time : %02d/%02d/%02d \n", hr_val, min_val, sec_val);
Serial.print(time_string);
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (GPS_SoftSerial.available()) /* Encode data read from GPS while data is available on serial port */
gps.encode(GPS_SoftSerial.read());
/* Encode basically is used to parse the string received by the GPS and to store it in a buffer so that information can be extracted from it */
} while (millis() - start < ms);
void DegMinSec( double tot_val) /* Convert data in decimal degrees into degrees minutes seconds form */
degree = (int)tot_val;
minutes = tot_val - degree;
seconds = 60 * minutes;
minutes = (int)seconds;
mins = (int)minutes;
seconds = seconds - minutes;
seconds = 60 * seconds;
secs = (int)seconds;
- leeg.jpg (87.47 KiB) Viewed 2715 times
