I have a MAC with ventura 13.2.1 and trying to load circuitpython onto a RP2040. I am following all the options detailed on this page-
https://learn.adafruit.com/adafruit-kb2 ... cuitpython
My RP2040 shows up as a RP1/Rp2 device, that's fine. then I press the boot and reset buttons(the colors are mislabelled but I did it both ways_ boot red and then boot blue and the hit the other button as the reset.
Also tried the option of unplugging, holding boot button and replugging.
I downloaded and then dragged the current CircuitPython library into the device, At this point, the device is supposed to change to CurcuitPython... but does not. I also tried loading the libraries. no difference. Then tried the "nuke" option but it would not load into the device. Would major appreciate help.
RP2040 not loading circuitpython
- dastels
Re: RP2040 not loading circuitpython
I'm not clear on what you're doing since you're talking about libraries. You downloaded adafruit-circuitpython-adafruit_kb2040-en_US-8.1.0.uf2 from https://circuitpython.org/board/adafruit_kb2040/? And copied it to the RPi/Rp2 drive? When that copy finishes, RPi/Rp2 should unmount and the CIRCUITPY drive should mount. Libraries you copy to CIRCUITPY/lib.
- schaefer0
hi,
It is June 1, and I've got macosx ventura 13.4, and I've got the same issue.
With a new rp 2040 featherwing "black" I got the boot drive but when I dragged and dropped
ADAFRUIT_FEATHER_RP2040-20220117-v1.18.uf2 into RPI-RP2, and rebooted, the CIRCUITYPY drive never showed up.
I have an older featherwing "pink" that has no problems and also worked with mac osx catalina.
- schaefer0
If it helps, I can connect using a serial modem tool, I get a prompt, and typing help() returns:
Welcom to MicroPython
- dastels
