Problem with 'if'
GilbertGagne
Problem with 'if'
Post by GilbertGagne »
I am a newbie user of MicroPython with Thonny on a Raspberry Pi Pico board.
My program is reading a sensor in I2C that puts out 2 bytes (msb & lsb) of a 16 bit number in 2's complement.
The 16 bit number is scaled by dividing it by 4096.
This is my code, line 58 is the (else:) line:
   if msb > 0x7F:			#if bit7=1 (negative): do 2's complement
        data16 = ~((msb << 8) | lsb)	#1st do 1's complement
        data16 +1=			#then add 1
    else:
        data16 = (msb << 8) | lsb
    data16  /= 4096			#finally, div result by 4096
>>> %Run -c $EDITOR_CONTENT
  File "<stdin>", line 58
SyntaxError: invalid syntax
This is my first use of an 'if' statement. My understanding is obviously missing something.
Last edited by adafruit_support_carter on Thu Jun 01, 2023 1:00 pm, edited 1 time in total.
Reason: added [code] tags
edgjr
Re: Problem with 'if'
Post by edgjr »
First, it's easier to read if you use the "code" tags and paste in the code as it appears in the editor (including spaces).
Just as a guess, you have a typo in the line before the "else:"
else:
Not valid code in any language that I know... :D
Agree it's probably the typo on the line *before*.
Also, just to mention, the Python struct module is useful for turning multiple bytes into values.
https://docs.python.org/3/library/struct.html
blakebr
Post by blakebr »
Your code should read:
        data16 += 1				#then add 1
    else:
Good luck.
Bruce
GilbertGagne
It was a typo; after correction - no problem.
Thank you all for looking.
