Hi Folks,
When trying to run my ultimate GPS board with the Adalogger board,the data stream from the GPS is corrupted, looks like a baud rate issue, but have not been able to resolve. Here is a pic of the output:
Is this a board issue, how can I resolve?
Feather Ultimate GPS Real time Data issues
- mikeysklar
Re: Feather Ultimate GPS Real time Data issues
Which example code are you working with? Had you modified it?
Have you tried the GPS_SoftwareSerial_Parsing.ino example?
- Danmorr56
Thanks, will try this code. I am using a adalogger with the feather gps. At first, I thought this was a baud rate issue, but doesn't work with any baud rates.
Also seeing the issue running the echo test code. Has anyone else seen this type of issue, scrambled data output? The Adalogger is working, it's a problem with the GPO I believe....
- Danmorr56
Echo test screen shot
- Echotest.PNG (105.99 KiB) Viewed 63 times
- mikeysklar
Can you post some photos of the Feathers, wiring and soldering you have done?
- Danmorr56
Feather GPS with Logger on headers
- 20230609_104309.jpg (65.9 KiB) Viewed 43 times
