board: adafruit esp32 huzza feather V2
os: adafruit-circuitpython-adafruit_feather_esp32_v2-en_US-8.1.0.bin
libs: adafruit-circuitpython-bundle-8.x-mpy-20230601
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
cs_pin = digitalio.DigitalInOut(board.D15)
ready_pin = digitalio.DigitalInOut(board.A4)
reset_pin = digitalio.DigitalInOut(board.A0)
esp = esp32spi.ESP_SPIcontrol(spi, cs_pin, ready_pin, reset_pin)
import time
import board
import busio
import adafruit_sgp30
import neopixel
import digitalio
import adafruit_esp32spi.adafruit_esp32spi as esp32spi
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_requests as requests
import ssl
# Initialize Neopixel on pin D0 with 1 LED
pixel_pin = board.NEOPIXEL
num_pixels = 1
pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=1)
test = dir(board)
print(test)
# Set up Adafruit.io credentials
AIO_USERNAME = "user"
AIO_KEY = "key"
AIO_GROUP = "adafruit"
AIO_FEED_ECO2 = "sgp30-eCO2"
AIO_FEED_TVOC = "sgp30-TVOC"
# Create an HTTPS socket and connect to Adafruit.io
socket.set_interface(esp)
context = ssl.create_default_context()
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Connect the socket to the server
server_address = ("io.adafruit.com", 443)
sock.connect(server_address)
# Wrap the socket with SSL
wrapped_sock = ssl.wrap_socket(sock, server_side=False, ssl_context=context)
# Function to send data to Adafruit.io
def send_to_adafruit_io(value):
url = "https://io.adafruit.com/api/v2/{}/feeds/{}/data".format(AIO_USERNAME, AIO_FEED)
payload = {"value": value}
headers = {"X-AIO-KEY": AIO_KEY, "Content-Type": "application/json"}
response = adafruitio.post(url, json=payload, headers=headers)
print("Data sent to Adafruit.io:", response.text)
# Define the pulse function
def pulse_green():
for i in range(0, 255, 5):
if i <= 162:
b = i
pixels[0] = (0, i, b)
# time.sleep(0.01)
time.sleep(0.01)
for i in range(255, -1, -5):
if b > 4:
b = b - 5
time.sleep(0.01)
def pulse_yellow():
for i in range(0, 256, 5):
pixels[0] = (i, i, 0)
time.sleep(0.01)
time.sleep(0.01)
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
# Create library object on our I2C port
sgp30 = adafruit_sgp30.Adafruit_SGP30(i2c)
print("SGP30 serial #", [hex(i) for i in sgp30.serial])
# sgp30.set_iaq_baseline(0x8973, 0x8AAE)
# sgp30.set_iaq_relative_humidity(celsius=23, relative_humidity=44)
elapsed_sec = 0
c = 0
while True:
# Pulse the pixel with green blue color 0,162,255
print("eCO2 = %d ppm \t TVOC = %d ppb" % (sgp30.eCO2, sgp30.TVOC))
if c == 10:
c = 0
# Send the eCO2 data to Adafruit.io
send_to_adafruit_io(AIO_FEED_ECO2, sgp30.eCO2)
# Send the TVOC data to Adafruit.io
send_to_adafruit_io(AIO_FEED_TVOC, sgp30.TVOC)
# Wait for some time before sending the next data
time.sleep(3) # Adjust the delay as per your requirements
c = c + 1
time.sleep(1)
elapsed_sec += 1
if elapsed_sec > 10:
elapsed_sec = 0
print(
"**** Baseline values: eCO2 = 0x%x, TVOC = 0x%x"
% (sgp30.baseline_eCO2, sgp30.baseline_TVOC)
if sgp30.eCO2 > 400 and sgp30.TVOC == 0:
print(
"***** eCO2 level > 400 Pulse Yellow*****")
pulse_yellow()
if sgp30.eCO2 > 400 or sgp30.TVOC > 0:
print(
pulse_yellow()
else:
pulse_green()
