Hi. I'm using the Adafruit DS1307 Real Time Clock with a Raspberry Pi Model 4b. It's meant to work at 3.3V, but I can only get it to work at 5V.
Does anyone have any suggestions?
Thanks.
Adafruit DS1307 Real Time Clock Not working at 3,3V
- bob59372
- dastels
Re: Adafruit DS1307 Real Time Clock Not working at 3,3V
It requires 5v. From https://learn.adafruit.com/adding-a-rea ... ng-the-rtc
DaveConnect VCC on the breakout board to the 5.0V pin of the Pi (if using DS1307)
Connect VCC on the breakout board to the 3.3V pin of the Pi (if using PCF8523 or DS3231)
- bob59372
Thank you.
I need a comment from an Adafruit Engineer on this, due to a product claim.
Kind regards,
Bob
Kind regards,
Bob
What claim are you referring to? The product description says that it requires 5v power to work.
https://www.adafruit.com/product/3296
- dastels
I assume you are referring to
That just says you can interact with it using 3.3v logic, i.e. a processor that uses 3.3v logic. Like the Pi, for instance. It does not say it can be powered with 3.3v.(although we've used it with 5V power and 3.3V logic successfully)
