Global Shutter Camera - Fails to Enable ENOSPC
LokoManiac
Post by LokoManiac »
Order #3078284-9094437790
Pulled camera out of the box, plugged it into my RPi Zero 2, enabled legacy camera on Bullseye through raspi-config, rebooted. Opened terminal, raspistill -o image.jpg, and I get the following error message:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
followed by "mmal: camera component couldn't be enabled.... failed to create camera component.... Please check for firmware update"
https://forums.raspberrypi.com/viewtopic.php?t=232533
I went to the Raspberry Pi forums, and was recommended to check vcgencmd get_camera. I get "supported=1 detected=1, libcamera interfaces=0"
I went to /boot/config.txt, added start_debug=1, rebooted, ran raspistill again, and get messages of "cannot load camera driver".
I increased the graphical memory to 144 and tried again, with the same messages. I changed the memory to 200, same messages.
I pulled the SD card and installed Buster, followed the same aforementioned steps, and I get the same set of messages.
I get my Pi 3, repeat the same set of steps for both Bullseye and Buster.
I ran across this forum post, which is identical in issue; viewtopic.php?f=8&t=137677. No posted resolution.
No other software I have attempted to use to get an image from this camera works. All of my connections are fine, and I have only disconnected the camera while powered off. I have a V1.3 camera that works fine. No other HQ or GS camera to try.
mikeysklar
Re: Global Shutter Camera - Fails to Enable ENOSPC
Post by mikeysklar »
Thank you for the troubleshooting summary.
Do you know which ribbon connector you are using with the camera? The Pi Zero family uses a different ribbon than the full size Pi’s.
To use with a Pi Zero, you will need an adapter cable, which we stock here!
*Raspberry Pi Zero models require a Raspberry Pi Zero camera cable (sold separately) to connect.
LokoManiac
I am using the recommended FPC cable for the Pi Zero that was linked on the GS Camera shop page.
mikeysklar
Thank you for the ribbon clarification. Let’s try a replacement camera.
Please e-mail [email protected] to request a replacement. They will need a link to this forum thread as authorization and your order#.
LokoManiac
After a great deal of tinkering, I figured out the issue. I don't know exactly why, but I know how to make the camera work.
If I start from a fresh installation, go straight to using libcamera. The camera works and has no issues. Don't do anything in raspi-config to enable the legacy camera. When I do, I get the error messages that I got before. If I disable legacy camera, the error still persists. So just use libcamera and picamera2 with the HQ and Global Shutter cameras.
mikeysklar
Thank you for this it will help others to avoid using the legacy camera settings and legacy tools like raspistill.
