What is the smallest Arduino compatible Adafriut board that has external hardware interrupt input?
Hardware Interrupt
- postfacto
Re: Hardware Interrupt
On the nano I would connect to pin 2 and code "attachInterrupt(0, checkSensor, RISING);"
Is it the same for the Trinket MO?
For the trinket M0, you can use any of the GPIO pins. Then use the digitalPinToInterrupt() function to determine which interrupt number is associated with it.
For example:
https://reference.arduino.cc/reference/ ... interrupt/
For example:
attachInterrupt(digitalPinToInterrupt(interruptPin), checkSensor, RISING);
- postfacto
What is the voltage input range?
For power to the BAT pin: 3-6v.
For inputs to GPIO pins: max 3.3v.
https://learn.adafruit.com/adafruit-tri ... no/pinouts
