Order #3009466-2731831081 - Shipped
Lithium Ion Polymer Battery - 3.7v 2500mAh PID: 328
I just tried to charge it for the first time and my huzzah esp8266 and 32 will not charge it. It also seems to make the esp8266 led flicker when I plug it in. any idea what could be wrong with new cell?
thanks
2500mAh cell dead
Re: 2500mAh cell dead
What voltage do you see on on the LiPo when it isn't connected to anything?
- AmicusFinch
the meter reads 3.68-3.69.
That's a normal voltage for a LiPo, so we can probably rule out something like an internal short circuit.
Post a photo showing the LiPo and its JST connector please. 800x600 images usually work best.
- AmicusFinch
I have attached it to several huzzah 8266 and 32. non of them charge it or turn on with it. Board also need to be flashed after I plugged in? not sure what else to try? thanks
- AmicusFinch
attached are 2 pics
- plug and battery
- IMG_0539.jpeg (924.64 KiB) Viewed 78 times
- plug
- IMG_0542.jpeg (808.83 KiB) Viewed 78 times
Sorry for the delay.
What voltage do you see on the Feather's BAT pin when the LiPo is connected?
- AmicusFinch
all good. recycled and ordered a few from digikey. thanks
