Adafruit Feather nRF52840 Sense is not getting readings with an hx711. In searching the forums it seems there are known some issues with possible solutions but do not see specifically see one for this board. It works fine on the same code on an arduino nano so confident the issue is some type of pinout or compatibility. If there is a better load cell amplifier that is known to work willing to change. The serial just reads 0 for reading FYI.
Adafruit Feather nRF52840 Sense hx711
- barshatriplee
Re: Adafruit Feather nRF52840 Sense hx711
Make sure that you have installed the necessary libraries for the HX711 on the Feather nRF52840 Sense. The library should be compatible with the nRF52840 chipset. Double-check that you have the correct library version and that it supports your board.
- curiouskk
Appreciate a link to the one you know is correct. Further research supports that this maybe a hardware incompatibility issue. If not I would appreciate if you have direct experience with standard HX711 anfd nRF52840.
https://forum.arduino.cc/t/tension-load ... s/676964/7
