DotStar Pi Painter HELP !
MiniPOV4 and previous versions
ludwig_pop
Post by ludwig_pop »
Hi everyone,
I'm french photographer. I started this project : https://learn.adafruit.com/dotstar-pi-p ... y-pi-setup
I follow all steps to set-up the raspberry (raspberry pi 2 + raspberry Pi OS Lite 32).
But after doing: pyhton 3 DotStarPiPainter.py
I have an error message:
python3: can't open file '/home/lightpainting/DotStarPiPainter.py': [errno2] no such file or directory.
Can you help me?
Merci beaucoup :)
mikeysklar
Re: DotStar Pi Painter HELP !
Post by mikeysklar »
Can you try typing the following from where you had run the python command?
pwd
ls *.py
The command you had used to launch the program has typos, but if I can see the full path I might should be able to correct it for you.
ludwig_pop
Thank you for your reply.
I typed your instructions.
pwd
The console displays :
/home/lightpainting
ls *.py
ls: cannot access '*.py' : No such fileor directory
I've joined a screenshot at this post.
mikeysklar
Thank you.
It looks like there is no code there. At least not a python script.
Based on the guide instructions you should have the script here.
cd DotStarPiPainter
python3 DotStarPiPainter.py
If all goes well, nothing should happen…it’s waiting for a USB drive to be inserted. Plug in a USB flash drive with one or more images on it, and after a moment you should see it print a message that it’s loading and processing an image. Fantastic! Press Control+C to break out of the program and we’ll do some final setup.
Were you able to follow all the steps on this guide page? There are several components to install.
ludwig_pop
Thank you for your help. I have entered your orders. I can run the python script fine. Unfortunately, I have an error. :(
File "/DotStarPiPainter.py", Line 48, in <module>
from lightpaint import LightPaint
ImportError: /home/lightpainting/DotStarPiPainter/lightpaint.so: undefined symbol: __pow_finite
I finded an post on this forum where this problem is mentioned : viewtopic.php?t=185938&start=15
For what it's worth, thought I'd report back on some findings.
Application was failing using RPi Lite (32 bit) 10/30/21 release.
Application runs using RPi Lite (Legacy) 2/12/21 release.
Not sure why, but no errors.
Problem I'm still working on its that the app recognizes my usb drive when I plug it in, but finds zero files (I added some code to spit out how many).
If i understand, I have a problem with my OS version ! I will try to reinstall my raspberry whith RPi Lite (Legacy) : https://www.raspberrypi.com/software/operating-systems/
I will share my experience on this post.
mikeysklar
Good find, but that forum thread you linked to is a 2 year old post so the Legacy Rpi Lite build 2/12/21 release has been replaced with a newer Legacy Lite 3/5/23.
Lets start with what version of Pi OS do you currently have installed? Please share the output from this command.
cat /etc/os-release
As the guide you have been following indicates you need to recompile the library.
thread you linked to is a 2 year old post so the Legacy Rpi Lite build 2/12/21 release has been replaced with a newer Legacy Lite 3/5/23. The current legacy build may work for you so please give it a try.
I went ahead and built it on my Pi4 running Bullseye. You can let me know if it works for you.
FWIW, I did have to remove some hard coding in the source.
* lightpaint.c - change from including python3.5 to any python release.
#include <Python.h>
* Makefile - added compiler flags to include python3.9 folder
CFLAGS = -fPIC -Ofast -fomit-frame-pointer -funroll-loops -I/usr/include/python3.9
I've attached the library and modified files for you to try with your current Pi OS install.
DotStarPiPainter-updated.zip
(82.38 KiB) Downloaded 115 times
mikeysklar
I opened and issue with the DotStarPiPainter github repo about the source code needing to be rebuilt for Pi OS Bullseye and the suggested source changes (style).
ludwig_pop
Thank you for help !
I lanch this code :
cat /etc/os-release
My raspberry show :
pi@raspberrypi:~ $ cat /etc/os-releasepi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
ludwig_pop
Then, i apply your modifications in lightpaint.c et Makefile.
lightpaint.c - i replace
#include <python3.5/Python.h>
by
#include <Python.h>
Makefile - i replace
by
Unfortunately, i have the same error when i launch DotStarPiPainter.py :
pi@raspberrypi:~/DotStarPiPainter $ python3 DotStarPiPainter.py
  File "/home/pi/DotStarPiPainter/DotStarPiPainter.py", line 48, in <module>
ImportError: /home/pi/DotStarPiPainter/lightpaint.so: undefined symbol: __pow_finite
mikeysklar
You made the correct changes, but you need to run the ‘make’ command (just once) before running the python script.
make
ludwig_pop
Awesome ! The script works :) Thanks
But nothing happens when I plug in the USB stick.
99_lightpaint_mount and 99_lightpaint_umount are in the good directory.
But, i've not finded "MountFlags=slave" on the system file => /lib/systemd/system/systemd-udevd.service
mikeysklar
Show me that the mount / umount files are in the correct location. Your previous screen shot showed them in your home directory, but they need to be under the respective /etc/usbmount folders as the instructions show:
cd DotStarPiPainter
sudo cp 99_lightpaint_mount /etc/usbmount/mount.d
sudo cp 99_lightpaint_umount /etc/usbmount/umount.d
Run these commands to show me they are there:
ls /etc/usbmount/mount.d
ls /etc/usbmount/umount.d
Did you modify the system-udevd.service file? Let's see the content.
cat /lib/systemd/system/systemd-udevd.service
ludwig_pop
I did the instructions :
cd DotStarPiPainter
I verify if files are in the correct location.
My raspberry shows :
pi@raspberrypi:~/DotStarPiPainter $ ls /etc/usbmount/mount.d
00_create_model_symlink  99_lightpaint_mount
pi@raspberrypi:~/DotStarPiPainter $ ls /etc/usbmount/umount.d
00_remove_model_symlink  99_lightpaint_umount
I don't modify : /lib/systemd/system/systemd-udevd.service
pi@raspberrypi:~/DotStarPiPainter $ cat /lib/systemd/system/systemd-udevd.service
#  SPDX-License-Identifier: LGPL-2.1-or-later
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit]
Description=Rule-based Manager for Device Events and Files
Documentation=man:systemd-udevd.service(8) man:udev(7)
DefaultDependencies=no
After=systemd-sysusers.service systemd-hwdb-update.service
Before=sysinit.target
ConditionPathIsReadWrite=/sys
[Service]
DeviceAllow=block-* rwm
DeviceAllow=char-* rwm
Type=notify
# Note that udev will reset the value internally for its workers
OOMScoreAdjust=-1000
Sockets=systemd-udevd-control.socket systemd-udevd-kernel.socket
Restart=always
RestartSec=0
ExecStart=/lib/systemd/systemd-udevd
ExecReload=udevadm control --reload --timeout 0
KillMode=mixed
TasksMax=infinity
PrivateMounts=yes
ProtectClock=yes
ProtectHostname=yes
MemoryDenyWriteExecute=yes
RestrictAddressFamilies=AF_UNIX AF_NETLINK AF_INET AF_INET6
RestrictRealtime=yes
RestrictSUIDSGID=yes
LockPersonality=yes
IPAddressDeny=any
WatchdogSec=3min
Un grand merci !
mikeysklar
It looks like you found another issue with the guide related to a Pi OS update.
Starting with Pi OS Buster the syntax has changed for getting usbmount to work.
Try the following.
sudo nano /lib/systemd/system/systemd-udevd.service
In the [Service] section of the configuration file add this line:
PrivateMounts=no
restart udevd:
sudo systemctl restart systemd-udevd
Now is your USB drive detected on insertion?
ludwig_pop
All works fine ! The script read only usb key fomated on FAT32.
Merci.
Return to “MiniPOV”
