Dear Adafruit,
I am writing to request the return of a product that I recently purchased from your store. Below are the details of the purchase:
Product: USB to UART Converter
Order/Invoice Number: #3231827-3317523454
Purchase Date: 12/02/2024
Unfortunately, despite multiple attempts, I have been unable to get the USB to UART converter to connect properly with the screen I am using. I have followed all the instructions in the manual and have tried different devices and cables, but there is no way to make the product work as expected.
Since the product does not fulfill its intended purpose and cannot be used for the function for which it was purchased, I kindly request a return and a corresponding refund. Attached to this letter are the purchase receipt and any other documents necessary to process the return.
Thank you in advance for your attention to this matter. Please contact me through the means mentioned above for any additional information you may need.
Sincerely,
Sergio Vega
GPA INNOVA
Adafruit PiUART - USB Console and Power Add-on for Raspberry Pi PID: 3589
- SergioVega
- 1720086629491.jpg (601.37 KiB) Viewed 794 times
- 1720086629474.jpg (236.24 KiB) Viewed 794 times
- 1720086629459.jpg (204.52 KiB) Viewed 794 times
- T_Mo
Re: Adafruit PiUART - USB Console and Power Add-on for Raspberry Pi PID: 3589
Probably better if you had not used a metal nut on the mounting screw - considering the exposed surface mount components right next to the nut.
We only do full refunds and replacements for production defects and early component failures.
The fact that you couldn't integrate the device into a circuit you developed doesn't count as a hardware failure.
We have an at-will return policy for devices purchased in the last 30 days that are still in original condition, but the customer is required to pay return shipping. In this case, the soldering to the PCB makes the device ineligible for at-will return.
- melvas66
I'm writing to request a return for a USB to UART Converter I purchased (Order #3231827-3317523454, on 12/02/2024). Despite following all instructions and trying various devices and cables, the product does not work as expected. As it cannot fulfill its intended purpose, I request a return and refund. I've attached the purchase receipt and necessary documents. Please let me know if you need any further information.
Your Texas Benefits
Your Texas Benefits
- Franklin97355
@melvas66 what does it not do "as expected"? Are you sure the switch is in the on position? Which version of pi are you using it with?
