Troubleshoot LED Matrix Cube
Report issues with the Adafruit Playground editor and display here.
(This forum is not for Circuit Playground board issues.)
Post Reply
alquin_cook
Post by alquin_cook »
I followed the RGB LED Matrix Cube with 25,000 LEDs guide and even made the code changes mentioned here viewtopic.php?t=214706&hilit=RGB+LED+Matrix+Cube to get the cube working.
However, now I need some help troubleshooting the top and left panels. The panels do not display the words correctly from the images/minecraft.png. The other panels are working correctly.
I have disassembled the cube and check the connections several times. I have tried running the globe program, but I am still having the same problem.
Are there any recommendations on how to fix this problem?
top panel.jpg (481.42 KiB) Viewed 167 times
left panel.jpg (375.24 KiB) Viewed 167 times
right panel.png (491.12 KiB) Viewed 167 times
Works
alquin_cook
Re: Troubleshoot LED Matrix Cube
I am having the same issue found here: viewtopic.php?t=193055
I have re-soldered my GPIO 4 to 18 jumper and the E8 jumper.
mhhf
Post by mhhf »
I had the same issue. Solved it by increasing the gpio_slowdown from 4 to 5, although it doesn't as 'good' anymore, the image doesn't glitches.
You can find the setting in the imageviewer.py among other things.
adafruit_support_carter
That'd be an easy thing to try. Looks like the original project was based on a Pi4:
https://learn.adafruit.com/rgb-led-matr ... i/overview
So if using a Pi5, may need more slow down.
Post Reply
Return to “Issues with the Adafruit Playground”
